- Fanuc 10T Direct drawing dimension programming
Hello all machinist
I have problem with Direct drawing dimension programming.
My lathe does not recognize if i programming roundings to corners.
Example if i write command:
z-10x40R2:
z-20:
Lathe only turns z-10x40 and then moves z-20, but doesnt not make 2mm rounding to corner.
I know that some other fanucs needs , symbol before R. i tried it, but that didn`t works.
Ideas what is wrong?
Re: Fanuc 10T Direct drawing dimension programming
Hiya
The option was probably not required at time of original purchase and was not activated in the parameters
Hi Kesseli
That looks like the Fanuc manual so would show it but does not mean it was activated by the manufacturer
- You may not post replies
- You may not edit your posts
Forum Rules
