Find M-Codes in PMC-L ladder dump? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
Thread: Find M-Codes in PMC-L ladder dump?
  1. #21
    Apr 2011
    Default Re: Find M-Codes in PMC-L ladder dump?
    If you go to coil Y48.4 in your ladder and scroll up you will come across a function block SUB9 COM. What this function block does is set all the coils to OFF between the SUB9 and SUB29 COME (COM END). If you scroll down you will see SUB29. Your clamping circuit is between these two SUBs. If SUB9 is on the logic works as if you didn't use COM in the first place. You will have to verify that COM is on when you are trying to clamp.
  2. #22
    Dec 2005
    Quote Originally Posted by drdos View Post
    I think the output port check Y48.4/Y48.5 in N00253 and N00254 was canceling itself out. Does this look workable?
    Find M-Codes in PMC-L ladder dump?-screen-shot-2020-03-27-6-41-a
  3. #23
    Dec 2005
    Mr. Yasuda caught a typo in N00253. He said with the fix the ladder should work. I'll burn new eproms and give it a go on Monday.
    Find M-Codes in PMC-L ladder dump?-p_20200328_141106-jpgFind M-Codes in PMC-L ladder dump?-screen-shot-2020-03-27-11-14-a
