Well not sure if this'll help. On my Hitachi Seiki I learned that there is a limit thrust engagement plate on the end of my Z axis ballscrew where the motor n belt pulley is. I had to manually turn the screw moving the the Z back away from the chuck. Then I was able to snap the engagement plate back into place.
Good luck.
Sent from my SM-G950U using Tapatalk
