Recently acquired a Hwacheon Lathe with 0T-C controller (first cnc lathe), and I use Fusion 360 for all of my CAM for milling and wanted to continue using it for turning. I would like to use a USB to transfer the files to the Fanuc and given that the files on the usb are fairly small (less than 1MB), can I simply use a USB to DB25 to transfer the files or is it better practice to drip feed?
Get one of these very reliable adapters, (link below) you'll also need a small cable DB9-DB25 wired for Fanuc .(Google it) and some file transfer software. I use dnc4u. It is very good, highly configurable and low cost.
