We have a kuraki with Fanuc 15 controls. When a program calls for a tool which is already in spindle, the machine alarms out. I have tried putting IF THEN statements in the M906 tool change program but the alarm supersedes anything I put in the program. Anyone know the location of alarm so I may be able to turn it off or change it to ignore the fact it's calling a tool it already has and continues to run the program being sent?
Pm if necessary.
1) Fix your programming so this doesn't happen. I never have this problem, why are you?
2) Put a block skip in front of the tool change call(s) for any tool that this always happens on. Even if you only turn it on to get the program going after a left over tool in the spindle, it fixes the problem.
3) There may be a parameter, Keep Realy or Diagnostic Bit setting that changes this alarm action. You will need the MTB literature supplied with the machine to see if this can be changed. Don't think you'll find it in any Fanuc book.
