Extract ALL variables from NTX 1000 CNC (FANUC controller)
Hi All, I have a DMG Mori NTX 1000 CNC machine (1st generation) which has FANUC controller. If I'm not wrong it's FANUC F31iB5.
Is it possible to extract and save values from ALL variables (there is around 10k of them) at the same time (they need to be synchronized)? If yes, then how can I do that?
Re: Extract ALL variables from NTX 1000 CNC (FANUC controller)
You can use the "ALL IO" menu under SYSTEM.
Set your IO device to 4 for PCMCIA.
You'll have the choice of doing each FILE one at a time.
If you have a PMC you may need a password from your Mori dealer to back up the parameters as they can only be done through the PMC
