Need Help! Lokesh machine 800 oi-md bypass A axis rotary!!!!
Results 1 to 9 of 9
Thread: Lokesh machine 800 oi-md bypass A axis rotary!!!!
    Dec 2015
    Default Lokesh machine 800 oi-md bypass A axis rotary!!!!
    hi all, we have Lokesh vmc 800 machine with Fanuc oi-md control MTB have made this with 4 axis but we need need only 3 axis.so unplugged all connectors and unplugged rotary axis. now the problem is controller have ladder have which have 4(a) axis reference condition. i need to bypass it 4(A) axis, from controller i changed parameter 8130-3 there is no parameters of 1010 & 9900 for axis control select, in position is also show 3 axis but after release emergency its shows A axis reference alarm which i attached above picture. i checked all PMC Parameters nothing bypassed also checked all keep relay's nothing happened. any help how i should bypass 4(A) axis rotary from machine. which i think need to edit ladder delete all conditions of 4axis????
    please help if anyone know the problem.
    thanks for help.
    Attached Thumbnails Attached Thumbnails Lokesh machine 800 oi-md bypass A axis rotary!!!!-img_20191212_175711187-jpg   Lokesh machine 800 oi-md bypass A axis rotary!!!!-img_20191212_155308916-jpg   Lokesh machine 800 oi-md bypass A axis rotary!!!!-img_20191212_142438621-jpg
    Apr 2011
    Default Re: Lokesh machine 800 oi-md bypass A axis rotary!!!!
    Make Keep Relay K00 bit 1 a 0. K00 xxxxxx0x x=don't change. Found under SYSTEM PMC Maint Far Right softkey, then Keep relays. PWE must be on and be in MDI mode.
    Dec 2015
    i already done it changed K00 1bit = 0 but nothing happen controller shows same alarm for A xis reference????? i think need to modify ladder or remove A axis from ladder.i dont what PMC parameters for A axis to bypass it???
    quick-cnc
    Dec 2015
    please check ladder if we bypass A axis reference alarm.
    thanks.
    Attached Files Attached Files
    quick-cnc
    Apr 2009
    The procedure of changing a ladder is best left to professionals. There also may be an issue with option changes needed on the control, which would require Fanuc to be involved.
    Dec 2015
    thanks memoryman for give right suggestion i will involve Fanuc for this work but i think here is also professionals which can do this work Rather than see what happens.
    quick-cnc
  7. #7
    Apr 2011
    Thanks for the ladder, you have to go to the Software Operator's Panel and turn it off. (ROTARY TABLE SELECTION IN SOP) Go to Offset/Settings then Right Softkey till you see ORP. Under this soft key you will fine select 4th axis. You must turn this off or un select it.
  8. #8
    Dec 2015
    thanks alot drdos alarm A axis bypass successfully from SOP button but now alarm EX1086 rotary table clamp failure exist on screen???
    could you please help me more by checking my ladder of machine???
    quick-cnc
  9. #9
    Quote Originally Posted by phucrobusl View Post
    thanks for help.
    i need 4 axis post processor
  10. #10
    Dec 2015
    sorry i can't understand what you need ??? please let me know which 4 axis Post processor you need??
    quick-cnc
