Hello all, I'm new and learning programming. Can someone please help me on backing up Fanuc programs all at once in individual files? I tried O-9999 but it saves as ALLPROG.txt and I need individual program backup for easy access.
Not sure if there's any specific format I can insert to get it worked. Please helpppp
I know of no way to do that. The closest thing to do is do what you've already done by copying them all at once, then take that file and separate them out form each other. Very simple copy and paste.
All you need to do is put a percent (%) sign at the very beginning and very end of each file.
You need DNC-software like f.e. Predator that can do the job.
Or when your machine is connected by Ethernet it can also be done.
Fanuc has a cheap tool for Ethernet connection and costs only €20,- in Europe ( $22,- )
Fanuc Program Transfer Tool - A08B-9510-J515, latest version 15 can also handle BIN-files on PCMCIA-flashcard.
Regards.
Heavy_Metal.
