Excel 510 Drip Feeding cannot enable G127.5
Results 1 to 10 of 10
Thread: Excel 510 Drip Feeding cannot enable G127.5
    May 2017
    Default Excel 510 Drip Feeding cannot enable G127.5
    I have gone through every message on this forum with no solution, although have learned some insight to my issue.
    problem is drip feeding
    Machine is Excel 510 Fanuc OM (not sure if A or B)
    It does have the Tape option (on the mode select dial anyway),
    I cannot change the G127.5 to a 1, with the dial or through MDI
    I know the tape selector is wired, because the diag shows that tape mode is selected (forget off hand which diag # changed when I select Tape)
    I can send and receive programs through my computer, so it seems the communication is setup ok. (unless I am missing something that allows regular communication but not drip feeding.)
    Everything I gather indicates it should be able to read from Tape but that darn G 127.5 just won't turn on.
    I cannot see the ladder.
    Is it possible I have an OMA (from which I gather would not be able to drip feed?)
    Any input/checklist or advise or referral would be much appreciated.
    Thanks in Advance.
    Dec 2009
    ROMANIA
    Default Re: Excel 510 Drip Feeding cannot enable G127.5
    hi
    please show me the diagnose from D600 to D700
    Meanwhile ,go in diagnose and go to D683.4 and make it 1 if is not and try and check ig G127.5 is 1.
    if it is already 1 ,make it 0
    good luck.
    PS:when the selector is on Tape Mode(DNC) in diagnose is changing X8.5
    May 2017
    cannot change D683.4 (you mean the diagnostic not parameter, correct?)
    when I output the diag screen , I receive as per file attached. it seems weird as it is incomplete.
    am I outputting correctly? I set the comp to receive the file, go to diag screen and press 'output'
    I can send screen shots as well if that will help.
    Attached Thumbnails Attached Thumbnails Excel 510 Drip Feeding cannot enable G127.5-img_2401-jpg   Excel 510 Drip Feeding cannot enable G127.5-img_2402-jpg   Excel 510 Drip Feeding cannot enable G127.5-img_2403-jpg   Excel 510 Drip Feeding cannot enable G127.5-img_2404-jpg
    Excel 510 Drip Feeding cannot enable G127.5-img_2405-jpg   Excel 510 Drip Feeding cannot enable G127.5-img_2406-jpg
    Attached Files Attached Files
    Mar 2017
    May 2017
    It seems this gentleman went in pretty deep with changing the ladder in the PMC chips.
    yikes, I would have to figure that out!
    May 2017
    I can't see the ladder. it is an OMB
    can I turn it on somehow?
    how do I find X8.5?
  7. #7
    Dec 2009
    ROMANIA
    yes it is corect.
    normal you should have the ladder printed on a book if is not available on screen
    the diagnose always is set with PWE=1 and emergency stop pushed.
    X8.5 is first page on diagnose ,on the row of 8 bit 5
  8. #8
    Apr 2009
    Diagnostic D503.4 must be set to 0 on the 510 machine. I've attached a copy of the 510 ladder for the 0M-B control. It has some of my notes in it but should cover what you need. I don't think that a Fanuc option is required for this to work. Excel has been out of business for a number of years.
    [url]www.shoprag.com[/url]
  9. #9
    May 2017
    I will give it a try. Thanks for the doc!
  10. #10
    May 2017
    Sweet Jesus it turned on G127.5 (when in tape mode)
    Llooks like can communicate through tape mode. Cycle starts initiates coms with computer. A few little things to sort out but I think this worked!
    Thank you so much!!!!!
