Need Help! Motor alarm light
Results 1 to 13 of 13
Thread: Motor alarm light
    Member steelcutter1960's Avatar
    Nov 2019
    Default Motor alarm light
    So I have a VMC Super max1 Rebel With Fanuc Series 0-M.
    I turn it on and get Not ready and motor alarm light?
    Has the encoder for motor gone bad?
    Attached Thumbnails Attached Thumbnails Motor alarm light-20191125_111407-jpg
    May 2016
    Default Re: Motor alarm light
    What motor alarm light? What number? Is your E-stop in or out?
    How long since the machine was last run?
    Nov 2019
    Friday e-stop out checked it twice.
    Nov 2019
    Light number?
    Attached Thumbnails Attached Thumbnails Motor alarm light-20191125_121321-jpg
    May 2016
    What number(s) appear on the servo amp(s)?
    May 2016
    Also can you get to the alarm or message screen and see if anything is there?
  7. #7
    Nov 2019
    alarm message
    Attached Thumbnails Attached Thumbnails Motor alarm light-20191125_132201-jpg
  8. #8
    Nov 2019
    I'm not to good at this is this helpful?
    - - - Updated - - -
    Or this
    Attached Thumbnails Attached Thumbnails Motor alarm light-20191125_132644-jpg   Motor alarm light-20191125_132650-jpg
  9. #9
    May 2016
    The servo tune screen screen (2nd soft button) has some more info including alarms. I'd have to dig deep into the books to find out what they mean, There are normally a few 1's there even when things are normal.
    When normal they should look like this. I have the same servos as you in my Max 3. (Motor ID 8 = Alpha C6)
    The servo tune screen will look like this when normal.
    Alarm 1 00000000
    Alarm 2 00000000
    Alarm 3 10000100
    Alarm 4 00000000
    Did you try pushing the "message" soft key (3rd one) when you had the alarm screen up?
    What about inside the control cabinet? For the 3rd time, do any numbers show up on the servo drives???
  10. #10
    Nov 2019
    09 flashes for a second then it goes to - -
  11. #11
    May 2016
    I don't see Alarm 09 being a servo alarm but a spindle alarm having to do with a fan possibly not operating. Or an overheat alarm.
    Do yourself a favor and google Fanuc 65165E and download the Fanuc Control Motor Alpha Series Maintenance Manual. cncspares has the /02 updated copy which is what you want for a machine of your vintage. There is tons in there that will help you along. including the Alarm 09 you're looking at.
    There is little I'm going to be able to help you with without being there and having greater access to what's going on.
    If you want to get this thing up and running quickly, you might just consider calling in a service person.
  12. #12
    Nov 2019
    Ok thanks for your help, have a good holiday.
  13. #13
    Member tetrateknoloji's Avatar
    Dec 2019
    Quote Originally Posted by the_gentlegiant View Post
    Alarm 1 00000000
    Alarm 2 00000000
    Alarm 3 10000100
    Alarm 4 00000000
    Merhaba fanuc amplifier üzerinde 2 alarmi var. Fön makinasi ile çalisiyor. Nasil tamir edebilirim. Hangi kompenet arizali.
Motor alarm light
Motor alarm light
Motor alarm light
