Originally Posted by
drdos
First, the 0C controller came in two types of PMC's. PMC-L and PMC-M. If you have PMC-M you will not have any EPROMS OE1 & OE2 on the Main Memory Board as these are reserved for PMC-L only. They will be on the PMC-M Board instead. You also are going to need to have an S0 Edit Cassette “A02B-0098-C199" plugged into the CEO slot of the mother board. This will give you an I/O screen in which to save or load in your programs. If you have PMC-M you will also need the PMC-M development board and that is based on your I/O type. Based on your parameter setting you told the controller that you have PMC-L. If you have PMC-M you will seethe I/O screen that you see. Please take a pic of your controller so I can see if you have PMC-L or PMC-M
