Hello all!
I recently bought a Takisawa TS-25 3-axis CNC lathe. I've been getting familiar with the machine and have encountered some problems.
I can contact the machine via CD4A RS-232 port, transfer files, backup parameters, use tape mode and drip feed.
The machine has a Remote Buffer card and as it has a c-axis with live tools and as I get it, the remote buffer offers faster execution of short G1's as there is no true look ahead in the control and G05.1 doesn't work (inappropriate G-code error)
Anyway, what happens is that when I put the machine to Tape mode, press cycle start and start transfer from PC, the program starts to 'move' and after a few seconds the hydraulics disengage and Trap 15 error screen comes up and IPL mode appears. That happens without a re-boot and the machine starts up normally after power cycle. If I do this with wrong stop bit setting for example, control doesn't crash.
Error leds seem to be like on this one: https://www.cnczone.com/forums/fanuc...tml#post823937 and the remote buffer card ha "waiting command from CNC controller led status.
And if I try to transfer file from CNC to PC via remote buffer (channel 10), the transfer doesn't start and the control pretty much hangs and only way to reset it is by power cycle. If I try to punch parameters via channel 10 (Remote Buffer), the punch starts but after about 1s, hydraulics turn off, control hangs completely and nothing is transferred.
Initially the status was that parameter punch crashed the control but nothing happened in tape mode or when trying to transfer the software. I suspected that the CD4 UART chips where gone and replaced them and only after that I managed to experience the Trap 15 issue.
Please find the parameter list below. Seems I can't have the list I pulled out from the machine a couple days ago with current comm settings, I can get proper list if needed, but don't think it's a comm issue.
Any help is greatly appreciated!
Code:
&FWPARAMETER :%
N0P00001000
N3P00000000
N10P00000000
N11P00000011
N12A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N20P1
N21P1
N22P1
N23P1
N31P1000
N32P10
N100P1494889
N101P28224
N102P310020
N103P54384
N104P183642
N105P0
N106P0
N107P80375
N108P0
N109P0
N1000P00000001
N1001P00000000
N1002P00000000
N1004A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1005A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1006A1P00001000A2P00000000A3P00000111A4P00000000A5P00000000A6P00000000
N1007A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1008A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1009A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1020A1P88A2P90A3P67A4P0A5P0A6P0
N1021A1P0A2P0A3P0A4P0A5P0A6P0
N1022A1P1A2P3A3P0A4P0A5P0A6P0
N1023A1P1A2P2A3P3A4P0A5P0A6P0
N1024A1P0A2P0A3P0A4P0A5P0A6P0
N1025A1P0A2P0A3P0A4P0A5P0A6P0
N1030P0
N1031P1
N1032P1
N1033P3
N1034P0
N1035P0
N1036P0
N1050P0
N1051P0
N1052P0
N1053P0
N1054P0
N1055P0
N1056P0
N1057P0
N1058P0
N1059P0
N1181P00000000
N1182P0
N1183P0
N1184P0
N1185P0
N1186P0
N1187P0
N1188P0
N1191P0
N1192P0
N1193P0
N1194P0
N1195P0
N1196P0
N1197A1P0A2P0A3P0A4P0A5P0A6P0
N1200P00000000
N1220A1P224775A2P619370A3P0A4P0A5P0A6P0
N1221A1P0A2P10000A3P0A4P0A5P0A6P0
N1222A1P0A2P9000A3P0A4P0A5P0A6P0
N1223A1P0A2P-8500A3P0A4P0A5P0A6P0
N1224A1P0A2P-26000A3P0A4P0A5P0A6P0
N1225A1P0A2P-43500A3P0A4P0A5P0A6P0
N1226A1P0A2P-61000A3P0A4P0A5P0A6P0
N1240A1P0A2P0A3P0A4P0A5P0A6P0
N1241A1P0A2P0A3P0A4P0A5P0A6P0
N1242A1P0A2P0A3P0A4P0A5P0A6P0
N1243A1P0A2P0A3P0A4P0A5P0A6P0
N1244A1P0A2P0A3P0A4P0A5P0A6P0
N1245A1P0A2P0A3P0A4P0A5P0A6P0
N1260A1P0A2P0A3P360000A4P0A5P0A6P0
N1400P00010010
N1401P00000000
N1402P00000000
N1403P00000000
N1410P500
N1411P0
N1412P25
N1413P0
N1414P100
N1417P0
N1420A1P1200A2P1600A3P576A4P0A5P0A6P0
N1421A1P400A2P400A3P400A4P0A5P0A6P0
N1422A1P600A2P600A3P600A4P0A5P0A6P0
N1423A1P500A2P500A3P500A4P0A5P0A6P0
N1424A1P0A2P0A3P0A4P0A5P0A6P0
N1425A1P200A2P200A3P200A4P0A5P0A6P0
N1426P0
N1427A1P0A2P0A3P0A4P0A5P0A6P0
N1428P0
N1471A1P0A2P0A3P0A4P0A5P0A6P0
N1472A1P0A2P0A3P0A4P0A5P0A6P0
N1478A1P0A2P0A3P0A4P0A5P0A6P0
N1479A1P0A2P0A3P0A4P0A5P0A6P0
N1480A1P0A2P0A3P0A4P0A5P0A6P0
N1481A1P0A2P0A3P0A4P0A5P0A6P0
N1482A1P0A2P0A3P0A4P0A5P0A6P0
N1493P0
N1496P0
N1497P0
N1498P0
N1499A1P0A2P0A3P0A4P0A5P0A6P0
N1600A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1601P00000000
N1620A1P80A2P140A3P100A4P0A5P0A6P0
N1621A1P200A2P200A3P200A4P0A5P0A6P0
N1622A1P0A2P0A3P0A4P0A5P0A6P0
N1623A1P0A2P0A3P0A4P0A5P0A6P0
N1624A1P50A2P50A3P50A4P0A5P0A6P0
N1625A1P0A2P0A3P0A4P0A5P0A6P0
N1626A1P80A2P0A3P80A4P0A5P0A6P0
N1627A1P800A2P800A3P800A4P0A5P0A6P0
N1628A1P0A2P0A3P0A4P0A5P0A6P0
N1629A1P0A2P0A3P0A4P0A5P0A6P0
N1630P0
N1631P0
N1633P0
N1634P0
N1635A1P0A2P0A3P0A4P0A5P0A6P0
N1643A1P0A2P0A3P0A4P0A5P0A6P0
N1644A1P0A2P0A3P0A4P0A5P0A6P0
N1645A1P0A2P0A3P0A4P0A5P0A6P0
N1646P0
N1647P0
N1648P0
N1800P00000110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N1811P00000000
N1815A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1816A1P00110100A2P01110111A3P00000010A4P00000000A5P00000000A6P00000000
N1817A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1820A1P2A2P2A3P2A4P0A5P0A6P0
N1821A1P0A2P0A3P0A4P0A5P0A6P0
N1822A1P0A2P0A3P0A4P0A5P0A6P0
N1825A1P3000A2P3000A3P3000A4P0A5P0A6P0
N1826A1P0A2P0A3P0A4P0A5P0A6P0
N1827A1P300A2P300A3P20A4P0A5P0A6P0
N1828A1P20000A2P14000A3P5000A4P0A5P0A6P0
N1829A1P100A2P100A3P100A4P0A5P0A6P0
N1830A1P100A2P100A3P100A4P0A5P0A6P0
N1831A1P0A2P0A3P0A4P0A5P0A6P0
N1832A1P17000A2P11500A3P4300A4P0A5P0A6P0
N1833A1P0A2P0A3P0A4P0A5P0A6P0
N1834A1P0A2P0A3P0A4P0A5P0A6P0
N1835A1P0A2P0A3P0A4P0A5P0A6P0
N1837A1P0A2P0A3P0A4P0A5P0A6P0
N1838A1P0A2P0A3P0A4P0A5P0A6P0
N1849A1P0A2P0A3P0A4P0A5P0A6P0
N1850A1P4055A2P2647A3P0A4P0A5P0A6P0
N1851A1P10A2P0A3P0A4P0A5P0A6P0
N1852A1P672A2P1090A3P1170A4P0A5P0A6P0
N1853A1P-1574A2P-2360A3P-2289A4P0A5P0A6P0
N1854A1P-2526A2P-2625A3P-2485A4P0A5P0A6P0
N1855A1P136A2P287A3P27A4P0A5P0A6P0
N1856A1P-1215A2P-2571A3P-244A4P0A5P0A6P0
N1857A1P0A2P0A3P0A4P0A5P0A6P0
N1858A1P-8235A2P-8235A3P-8235A4P0A5P0A6P0
N1859A1P3124A2P1476A3P15580A4P0A5P0A6P0
N1860A1P0A2P0A3P0A4P0A5P0A6P0
N1861A1P0A2P0A3P0A4P0A5P0A6P0
N1862A1P956A2P956A3P956A4P0A5P0A6P0
N1863A1P510A2P510A3P510A4P0A5P0A6P0
N1864A1P0A2P0A3P0A4P0A5P0A6P0
N1865A1P21A2P21A3P70A4P0A5P0A6P0
N1866A1P3787A2P3787A3P1136A4P0A5P0A6P0
N1867A1P319A2P319A3P319A4P0A5P0A6P0
N1868A1P2520A2P3780A3P644A4P0A5P0A6P0
N1869A1P2330A2P2330A3P559A4P0A5P0A6P0
N1870A1P57A2P57A3P46A4P0A5P0A6P0
N1871A1P5A2P5A3P0A4P0A5P0A6P0
N1872A1P7282A2P7282A3P7282A4P0A5P0A6P0
N1873A1P120A2P120A3P120A4P0A5P0A6P0
N1874A1P64A2P65A3P46A4P0A5P0A6P0
N1875A1P88A2P143A3P18A4P0A5P0A6P0
N1876A1P10000A2P8000A3P12000A4P0A5P0A6P0
N1877A1P32694A2P32578A3P32627A4P0A5P0A6P0
N1878A1P924A2P2381A3P1766A4P0A5P0A6P0
N1879A1P111A2P-111A3P111A4P0A5P0A6P0
N1880P0
N1881P0
N1882P0
N1883A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1884A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1890A1P-20A2P-20A3P-20A4P0A5P0A6P0
N1891A1P10000A2P8000A3P12000A4P0A5P0A6P0
N1892A1P4A2P4A3P4A4P0A5P0A6P0
N1893A1P2740A2P7075A3P5245A4P0A5P0A6P0
N1894A1P0A2P0A3P0A4P0A5P0A6P0
N1895A1P0A2P0A3P0A4P0A5P0A6P0
N1896A1P0A2P0A3P0A4P0A5P0A6P0
N1910P0
N1912A1P0A2P0A3P0A4P0A5P0A6P0
N1913A1P0A2P0A3P0A4P0A5P0A6P0
N1914A1P0A2P0A3P0A4P0A5P0A6P0
N1915A1P0A2P0A3P0A4P0A5P0A6P0
N1916A1P0A2P0A3P0A4P0A5P0A6P0
N1920A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1921A1P0A2P0A3P0A4P0A5P0A6P0
N1922A1P0A2P0A3P0A4P0A5P0A6P0
N1923A1P0A2P0A3P0A4P0A5P0A6P0
N1924A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1925A1P0A2P0A3P0A4P0A5P0A6P0
N1926A1P0A2P0A3P0A4P0A5P0A6P0
N1930A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1931A1P0A2P0A3P0A4P0A5P0A6P0
N1932A1P0A2P0A3P0A4P0A5P0A6P0
N1933A1P0A2P0A3P0A4P0A5P0A6P0
N1934A1P0A2P0A3P0A4P0A5P0A6P0
N1935A1P0A2P0A3P0A4P0A5P0A6P0
N1936A1P0A2P0A3P0A4P0A5P0A6P0
N1940A1P0A2P0A3P0A4P0A5P0A6P0
N1941A1P0A2P0A3P0A4P0A5P0A6P0
N1942A1P0A2P0A3P0A4P0A5P0A6P0
N1943A1P0A2P0A3P0A4P0A5P0A6P0
N1944A1P0A2P0A3P0A4P0A5P0A6P0
N1945A1P0A2P0A3P0A4P0A5P0A6P0
N1946A1P0A2P0A3P0A4P0A5P0A6P0
N1947A1P0A2P0A3P0A4P0A5P0A6P0
N1948A1P0A2P0A3P0A4P0A5P0A6P0
N1949A1P0A2P0A3P0A4P0A5P0A6P0
N1950A1P0A2P0A3P0A4P0A5P0A6P0
N1951A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1952A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1953A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1954A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1955A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1956A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N1961A1P0A2P0A3P0A4P0A5P0A6P0
N1962A1P0A2P0A3P0A4P0A5P0A6P0
N1963A1P0A2P0A3P0A4P0A5P0A6P0
N1964A1P0A2P0A3P0A4P0A5P0A6P0
N1965A1P0A2P0A3P0A4P0A5P0A6P0
N1966A1P0A2P0A3P0A4P0A5P0A6P0
N1967A1P2100A2P2520A3P0A4P0A5P0A6P0
N1968A1P0A2P0A3P0A4P0A5P0A6P0
N1969A1P0A2P0A3P0A4P0A5P0A6P0
N1970A1P0A2P0A3P0A4P0A5P0A6P0
N1971A1P0A2P0A3P0A4P0A5P0A6P0
N1972A1P0A2P0A3P0A4P0A5P0A6P0
N1973A1P0A2P0A3P0A4P0A5P0A6P0
N1974A1P0A2P0A3P0A4P0A5P0A6P0
N1975A1P0A2P0A3P0A4P0A5P0A6P0
N1976A1P0A2P0A3P0A4P0A5P0A6P0
N1977A1P0A2P0A3P3A4P0A5P0A6P0
N1978A1P0A2P0A3P40A4P0A5P0A6P0
N1979A1P1353A2P2175A3P1872A4P0A5P0A6P0
N1980A1P0A2P0A3P0A4P0A5P0A6P0
N1981A1P0A2P0A3P0A4P0A5P0A6P0
N1982A1P0A2P0A3P0A4P0A5P0A6P0
N1983A1P0A2P0A3P0A4P0A5P0A6P0
N1984A1P0A2P0A3P0A4P0A5P0A6P0
N1985A1P0A2P0A3P0A4P0A5P0A6P0
N1986A1P0A2P0A3P0A4P0A5P0A6P0
N1987A1P0A2P0A3P0A4P0A5P0A6P0
N1988A1P0A2P0A3P0A4P0A5P0A6P0
N1989A1P0A2P0A3P0A4P0A5P0A6P0
N1990A1P0A2P0A3P0A4P0A5P0A6P0
N1991A1P0A2P0A3P0A4P0A5P0A6P0
N2000P00000000
N2001P00000000
N2002P00000000
N2003P00000000
N2004P00000000
N2005P00000000
N2010P64
N2011P64
N2012P0
N2013P0
N2014P1000
N2015P1000
N2016P25200
N2020A1P0A2P0A3P0A4P0A5P0A6P0
N2021A1P0A2P0A3P0A4P0A5P0A6P0
N2030P2
N2031P4
N2032P4
N2033P0
N2034P0
N2035P0
N2036P0
N2037P0
N2049P0
N2051P0
N2052P0
N2053P0
N2200P00011000
N2201P00000011
N2202P00000100
N2203P00000110
N2204P00000000
N2205P00000100
N2206P00000000
N2207P00000000
N2208P00000000
N2209P00000000
N2220P0
N2221P0
N2222P0
N2223P0
N2224P0
N2225P0
N2226P0
N2227P0
N2228P0
N2229P0
N2231P1
N2232P2
N2233P3
N2234P150
N2235P155
N2236P162
N2237P162
N2241P0
N2242P0
N2243P0
N2244P0
N2245P0
N2258P0
N2259P0
N2260P0
N2261P0
N2262P0
N2263A1P0A2P0A3P0A4P0A5P0A6P0
N2264A1P0A2P0A3P0A4P0A5P0A6P0
N2265P0
N2266P0
N2267P0
N2268P0
N2269P0
N2270P0
N2271P0
N2272P0
N2273P0
N2274P0
N2275P0
N2276P0
N2277P0
N2278P0
N2279P0
N2280P0
N2281P0
N2282P0
N2283P0
N2284P0
N2285P0
N2292P0
N2293P0
N2294P0
N2295P0
N2296P0
N2297P0
N2298P0
N2299P0
N2311P0
N2312P0
N2313P0
N2314P0
N2315P0
N2316P0
N2317P0
N2318P0
N2321P0
N2322P0
N2323P0
N2324P0
N2325P0
N2326P0
N2327P0
N2328P0
N2331P0
N2332P0
N2333P0
N2334P0
N2335P0
N2336P0
N2337P0
N2338P0
N2341P0
N2342P0
N2343P0
N2344P0
N2345P0
N2346P0
N2347P0
N2348P0
N2351P0
N2352P0
N2353P0
N2354P0
N2355P0
N2356P0
N2357P0
N2358P0
N2361P0
N2362P0
N2363P0
N2364P0
N2365P0
N2366P0
N2367P0
N2368P0
N2371P0
N2372P0
N2373P0
N2374P0
N2375P0
N2376P0
N2377P0
N2378P0
N2381P0
N2382P0
N2383P0
N2384P0
N2385P0
N2386P0
N2387P0
N2388P0
N2390P0
N2391P0
N2392P0
N2393P0
N2394P0
N2395P0
N2396P0
N2397P0
N2398P0
N2399P0
N2400P00010001
N2401P10010000
N2402P00000010
N2403P00000000
N2404P00000000
N2405P00000000
N2406P00000000
N2410P1000
N2411P0
N2412P0
N2413P0
N2414P0
N2415P0
N2416P0
N2417P0
N2418P0
N2421P0
N2422P0
N2423P0
N2424P0
N2425P0
N2426P0
N2428P0
N2431P0
N2432P0
N2481P0
N2482P0
N2483P0
N2484P0
N2503P0
N2504P0
N2505P0
N2506P0
N2510P0
N2900P0
N3000P00000000
N3001P00000000
N3002P00000000
N3003P00000000
N3004P00000000
N3005P00000000
N3006P00000000
N3007P00000000
N3008P00000000
N3009P00000000
N3010P00000000
N3011P00000000
N3012P00000000
N3013P00000000
N3014P00000000
N3015P00000000
N3016P00000000
N3017P00000000
N3018P00000000
N3019P00000000
N3020P0
N3021P0
N3022P0
N3023P0
N3024P0
N3025P0
N3026P0
N3027P0
N3028P0
N3029P0
N3030P0
N3031P0
N3032P0
N3033P0
N3034P0
N3035P0
N3036P0
N3037P0
N3038P0
N3039P0
N3040P0
N3041P0
N3042P0
N3043P0
N3044P0
N3045P0
N3046P0
N3047P0
N3048P0
N3049P0
N3050P0
N3051P0
N3052P0
N3053P0
N3054P0
N3055P0
N3056P0
N3057P0
N3058P0
N3059P0
N3060P0
N3061P0
N3062P0
N3063P0
N3064P0
N3065P0
N3066P0
N3067P0
N3068P0
N3069P0
N3070P0
N3071P0
N3072P0
N3073P0
N3074P0
N3075P0
N3076P0
N3077P0
N3078P0
N3079P0
N3080P0
N3081P0
N3082P0
N3083P0
N3084P0
N3085P0
N3086P0
N3087P0
N3088P0
N3089P0
N3090P0
N3091P0
N3092P0
N3093P0
N3094P0
N3095P0
N3096P0
N3097P0
N3098P0
N3099P0
N3100P0
N3101P0
N3102P0
N3103P0
N3104P0
N3105P0
N3106P0
N3107P0
N3108P0
N3109P0
N3110P0
N3111P0
N3112P0
N3113P0
N3114P0
N3115P0
N3116P0
N3117P0
N3118P0
N3119P0
N3120P0
N3121P0
N3122P0
N3123P0
N3124P0
N3125P0
N3126P0
N3127P0
N3128P0
N3129P0
N3130P0
N3131P0
N3132P0
N3133P0
N3134P0
N3135P0
N3140P00000000
N3141P00000000
N3142P00000000
N3143P00000000
N3144P00000000
N3145P00000000
N3146P00000000
N3147P00000000
N3148P00000000
N3149P00000000
N3150P00000000
N3151P00000000
N3152P00000000
N3153P00000000
N3154P00000000
N3155P00000000
N3156P00000000
N3157P00000000
N3158P00000000
N3159P00000000
N3160P0
N3161P0
N3162P0
N3163P0
N3164P0
N3165P0
N3166P0
N3167P0
N3168P0
N3169P0
N3170P0
N3171P0
N3172P0
N3173P0
N3174P0
N3175P0
N3176P0
N3177P0
N3178P0
N3179P0
N3180P0
N3181P0
N3182P0
N3183P0
N3184P0
N3185P0
N3186P0
N3187P0
N3188P0
N3189P0
N3190P0
N3191P0
N3192P0
N3193P0
N3194P0
N3195P0
N3196P0
N3197P0
N3198P0
N3199P0
N3200P0
N3201P0
N3202P0
N3203P0
N3204P0
N3205P0
N3206P0
N3207P0
N3208P0
N3209P0
N3210P0
N3211P0
N3212P0
N3213P0
N3214P0
N3215P0
N3216P0
N3217P0
N3218P0
N3219P0
N3220P0
N3221P0
N3222P0
N3223P0
N3224P0
N3225P0
N3226P0
N3227P0
N3228P0
N3229P0
N3230P0
N3231P0
N3232P0
N3233P0
N3234P0
N3235P0
N3236P0
N3237P0
N3238P0
N3239P0
N3240P0
N3241P0
N3242P0
N3243P0
N3244P0
N3245P0
N3246P0
N3247P0
N3248P0
N3249P0
N3250P0
N3251P0
N3252P0
N3253P0
N3254P0
N3255P0
N3256P0
N3257P0
N3258P0
N3259P0
N3260P0
N3261P0
N3262P0
N3263P0
N3264P0
N3265P0
N3266P0
N3267P0
N3268P0
N3269P0
N3270P0
N3271P0
N3272P0
N3273P0
N3274P0
N3275P0
N3280P0
N3281P0
N3282P0
N3283P0
N3284P0
N3285P0
N3286P0
N3287P0
N3288P0
N3289P0
N3290P0
N3291P0
N3292P0
N3293P0
N3294P0
N3295P0
N3296P0
N3297P0
N3298P0
N3299P0
N3300P0
N3301P0
N3302P0
N3303P0
N3304P0
N3305P0
N3306P0
N3307P0
N3308P0
N3309P0
N3310P0
N3311P0
N3312P0
N3313P0
N3314P0
N3315P0
N3316P0
N3317P0
N3318P0
N3319P0
N3320P00000000
N3321P00000000
N3322P00000000
N3323P00000000
N3324P00000000
N3325P00000000
N3326P00000000
N3327P00000000
N3328P00000000
N3329P00000000
N3330P00000000
N3331P00000000
N3332P00000000
N3333P00000000
N3334P00000000
N3335P00000000
N3336P00000000
N3337P00000000
N3338P00000000
N3339P00000000
N3340P0
N3341P0
N3342P0
N3343P0
N3344P0
N3345P0
N3346P0
N3347P0
N3348P0
N3349P0
N3350P0
N3351P0
N3352P0
N3353P0
N3354P0
N3355P0
N3356P0
N3357P0
N3358P0
N3359P0
N3360P0
N3361P0
N3362P0
N3363P0
N3364P0
N3365P0
N3366P0
N3367P0
N3368P0
N3369P0
N3370P0
N3371P0
N3372P0
N3373P0
N3374P0
N3375P0
N3376P0
N3377P0
N3378P0
N3379P0
N3380P0
N3381P0
N3382P0
N3383P0
N3384P0
N3385P0
N3386P0
N3387P0
N3388P0
N3389P0
N3390P0
N3391P0
N3392P0
N3393P0
N3394P0
N3395P0
N3396P0
N3397P0
N3398P0
N3399P0
N3400P0
N3401P0
N3402P0
N3403P0
N3404P0
N3405P0
N3406P0
N3407P0
N3408P0
N3409P0
N3410P0
N3411P0
N3412P0
N3413P0
N3414P0
N3415P0
N3416P0
N3417P0
N3418P0
N3419P0
N3420P0
N3421P0
N3422P0
N3423P0
N3424P0
N3425P0
N3426P0
N3427P0
N3428P0
N3429P0
N3430P0
N3431P0
N3432P0
N3433P0
N3434P0
N3435P0
N3436P0
N3437P0
N3438P0
N3439P0
N3440P0
N3441P0
N3442P0
N3443P0
N3444P0
N3445P0
N3446P0
N3447P0
N3448P0
N3449P0
N3450P0
N3451P0
N3452P0
N3453P0
N3454P0
N3455P0
N3456P0
N3457P0
N3458P0
N3459P0
N3460P0
N3461P0
N3462P0
N3463P0
N3464P0
N3465P0
N3466P0
N3467P0
N3468P0
N3469P0
N3470P0
N3471P0
N3472P0
N3473P0
N3474P0
N3475P0
N3476P0
N3477P0
N3478P0
N3479P0
N3480P0
N3481P0
N3482P0
N3483P0
N3484P0
N3485P0
N3486P0
N3487P0
N3488P0
N3489P0
N3490P0
N3491P0
N3492P0
N3493P0
N3494P0
N3495P0
N3500P0
N3501P0
N3502P0
N3503P0
N3504P0
N3505P0
N3506P0
N3507P0
N3508P0
N3509P0
N3510P0
N3511P0
N3512P0
N3513P0
N3514P0
N3515P0
N3516P0
N3517P0
N3518P0
N3519P0
N3520P0
N3521P0
N3522P0
N3523P0
N3524P0
N3525P0
N3526P0
N3527P0
N3528P0
N3529P0
N3530P0
N3531P0
N3532P0
N3533P0
N3534P0
N3535P0
N3536P0
N3537P0
N3538P0
N3539P0
N3540P00000000
N3541P00000000
N3542P00000000
N3543P00000000
N3544P00000000
N3545P00000000
N3546P00000000
N3547P00000000
N3548P00000000
N3549P00000000
N3550P00000000
N3551P00000000
N3552P00000000
N3553P00000000
N3554P00000000
N3555P00000000
N3556P00000000
N3557P00000000
N3558P00000000
N3559P00000000
N3560P0
N3561P0
N3562P0
N3563P0
N3564P0
N3565P0
N3566P0
N3567P0
N3568P0
N3569P0
N3570P0
N3571P0
N3572P0
N3573P0
N3574P0
N3575P0
N3576P0
N3577P0
N3578P0
N3579P0
N3580P0
N3581P0
N3582P0
N3583P0
N3584P0
N3585P0
N3586P0
N3587P0
N3588P0
N3589P0
N3590P0
N3591P0
N3592P0
N3593P0
N3594P0
N3595P0
N3596P0
N3597P0
N3598P0
N3599P0
N3600P0
N3601P0
N3602P0
N3603P0
N3604P0
N3605P0
N3606P0
N3607P0
N3608P0
N3609P0
N3610P0
N3611P0
N3612P0
N3613P0
N3614P0
N3615P0
N3616P0
N3617P0
N3618P0
N3619P0
N3620P0
N3621P0
N3622P0
N3623P0
N3624P0
N3625P0
N3626P0
N3627P0
N3628P0
N3629P0
N3630P0
N3631P0
N3632P0
N3633P0
N3634P0
N3635P0
N3636P0
N3637P0
N3638P0
N3639P0
N3640P0
N3641P0
N3642P0
N3643P0
N3644P0
N3645P0
N3646P0
N3647P0
N3648P0
N3649P0
N3650P0
N3651P0
N3652P0
N3653P0
N3654P0
N3655P0
N3656P0
N3657P0
N3658P0
N3659P0
N3660P0
N3661P0
N3662P0
N3663P0
N3664P0
N3665P0
N3666P0
N3667P0
N3668P0
N3669P0
N3670P0
N3671P0
N3672P0
N3673P0
N3674P0
N3675P0
N3676P0
N3677P0
N3678P0
N3679P0
N3680P0
N3681P0
N3682P0
N3683P0
N3684P0
N3685P0
N3686P0
N3687P0
N3688P0
N3689P0
N3690P0
N3691P0
N3692P0
N3693P0
N3694P0
N3695P0
N3696P0
N3697P0
N3698P0
N3699P0
N3700P0
N3701P0
N3702P0
N3703P0
N3704P0
N3705P0
N3706P0
N3707P0
N3708P0
N3709P0
N3710P0
N3711P0
N3712P0
N3713P0
N3714P0
N3715P0
N4600P00000000
N4610P0
N4611P0
N4612P0
N4615P0
N4616P0
N4619P0
N4620P0
N4621P0
N4622P0
N4623P0
N4624P0
N4629P0
N4630P0
N4631P0
N4821P0
N4822P0
N4823P0
N4831P0
N4832P0
N4833P0
N4834P0
N4835P0
N4881A1P0A2P0A3P0A4P0A5P0A6P0
N4882A1P0A2P0A3P0A4P0A5P0A6P0
N4883A1P0A2P0A3P0A4P0A5P0A6P0
N5000P00000000
N5001P1
N5002P2
N5003P3
N5011P0
N5013P4
N5050P10
N5051P10
N5052P5
N5053P5
N5054P256
N5055P256
N5056P00001010
N5057P0
N5058P0
N5060P0
N5061P0
N5062P0
N5063P0
N5064P0
N5065P0
N5070P11
N5071P0
N5072P0
N5073P0
N5074P0
N5081P8
N5082P1
N5083P12
N5084P1
N5090P0
N5091P0
N5092P0
N5093P0
N5094P0
N5110P8
N5111P1
N5112P12
N5120P0
N5121P0
N5122P0
N5130P0
N5131P0
N5132P0
N5140P6
N5141P1
N5142P12
N5150P0
N5151P0
N5152P0
N5160P0
N5161P0
N5162P0
N5170P0
N5171P0
N5172P0
N5180P0
N5181P0
N5182P0
N5190P0
N5191P0
N5192P0
N5200P10000000
N5210A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N5220A1P10000A2P5000A3P99999999A4P99999999A5P99999999A6P99999999
N5221A1P-320000A2P-640000A3P-99999999A4P-99999999A5P-99999999A6P-99999999
N5222A1P99999999A2P99999999A3P99999999A4P99999999A5P99999999A6P99999999
N5223A1P99999999A2P99999999A3P-99999999A4P-99999999A5P-99999999A6P-99999999
N5224A1P99999999A2P99999999A3P99999999A4P99999999A5P99999999A6P99999999
N5225A1P-99999999A2P-99999999A3P-99999999A4P-99999999A5P-99999999A6P-99999999
N5226A1P0A2P0A3P0A4P0A5P0A6P0
N5227A1P0A2P0A3P0A4P0A5P0A6P0
N5229P0
N5230P0
N5231P0
N5232P0
N5233P0
N5234P0
N5235P0
N5236P0
N5241P0
N5242P0
N5243P0
N5244P0
N5245P0
N5246P0
N5247P0
N5248P0
N5270P0
N5271P0
N5272P0
N5273P0
N5274P0
N5275P0
N5276P0
N5277P0
N5278P0
N5279P0
N5280P0
N5281P0
N5282P0
N5283P0
N5284P0
N5285P0
N5286P0
N5287P0
N5288P0
N5289P0
N5290P0
N5291P0
N5292P0
N5293P0
N5294P0
N5295P0
N5296P0
N5297P0
N5298P0
N5299P0
N5420A1P0A2P0A3P0A4P0A5P0A6P0
N5421A1P0A2P0A3P0A4P0A5P0A6P0
N5422A1P0A2P0A3P0A4P0A5P0A6P0
N5423A1P0A2P0A3P0A4P0A5P0A6P0
N5424A1P0A2P0A3P0A4P0A5P0A6P0
N5425A1P0A2P0A3P0A4P0A5P0A6P0
N5426A1P00000000A2P00000000A3P00000000A4P00000000A5P00000000A6P00000000
N5430A1P0A2P0A3P0A4P0A5P0A6P0
N5431A1P0A2P0A3P0A4P0A5P0A6P0
N5432A1P0A2P0A3P0A4P0A5P0A6P0
N5433A1P0A2P0A3P0A4P0A5P0A6P0
N5461A1P0A2P0A3P0A4P0A5P0A6P0
N5462A1P0A2P0A3P0A4P0A5P0A6P0
N5463A1P0A2P0A3P0A4P0A5P0A6P0
N5464A1P0A2P0A3P0A4P0A5P0A6P0
N5471A1P0A2P0A3P0A4P0A5P0A6P0
N5472A1P0A2P0A3P0A4P0A5P0A6P0
N5473A1P0A2P0A3P0A4P0A5P0A6P0
N5474A1P0A2P0A3P0A4P0A5P0A6P0
N5481P0
N5482P0
N5483P0
N5491P0
N5492P0
N5493P0
N5501P0
N5502P0
N5503P0
N5504P0
N5511P0
N5512P0
N5513P0
N5514P0
N5521P0
N5522P0
N5523P0
N5524P0
N5551P0
N5552P0
N5553P0
N5554P0
N5561P0
N5562P0
N5563P0
N5564P0
N5571P0
N5572P0
N5573P0
N5574P0
N5580P00000000
N5581P0
N5582P0
N5583P0
N5591P0
N5592P0
N5593P0
N5600P00000000
N5601P00000000
N5602P01101000
N5603P00000000
N5604P00000000
N5605P00000000
N5606P00000000
N5607P00000000
N5608P00000000
N5609P00000000
N5610P0
N5611P2
N5612P0
N5613P0
N5614P800
N5615P0
N5616P0
N5617P0
N5618P0
N5619P0
N5620P0
N5621P0
N5622P0
N5623P0
N5624P0
N5625P0
N5626P0
N5627P0
N5628P0
N5631P0
N5632P0
N5633P0
N5634P0
N5635P0
N5636P0
N5637P0
N5640P0
N5641P1
N5642P0
N5643P0
N5644P0
N5645P0
N5646P0
N5647P0
N5648P0
N5660P0
N5661P0
N5662P0
N5663P0
N5664P0
N5680P0
N5681P0
N5682P0
N5683P0
N5691P0
N5692P0
N5693P0
N5694P0
N5695P0
N5696P0
N5697P0
N5698P0
N5701P0
N5702P0
N5703P0
N5704P0
N5705P0
N5706P0
N5707P0
N5708P0
N5709P0
N5710P0
N5721P0
N5722P0
N5723P0
N5724P0
N5725P0
N5726P0
N5751P0
N5752P0
N5753P0
N5754P0
N5755P0
N5756P0
N5757P0
N5758P0
N5759P0
N5760P0
N5761P0
N5762P0
N5763P0
N5764P0
N5765P0
N5766P0
N5767P0
N5771P0
N5772P0
N5773P0
N5774P0
N5775P0
N5776P0
N5777P0
N5778P0
N5781P0
N5782P0
N5783P0
N5784P0
N5785P0
N5786P0
N5787P0
N5788P0
N5791P0
N5792P0
N5793P0
N5794P0
N5795P0
N5796P0
N5797P0
N5798P0
N5801P0
N5802P0
N5803P0
N5804P0
N5810P0
N5811P0
N5820P00000000
N5990P0
N5991P0
N5992P0
N5993P0
N6000P10000000
N6001P00100100
N6002P01000000
N6003P00000000
N6004P00000000
N6005P00000000
N6006P00000000
N6010P20
N6012P0
N6013P999999
N6014P5000
N6015P-224381
N6016P-143698
N6017P-425206
N6018P-384731
N6025P0
N6026P0
N6040P0
N6041P0
N6042P0
N6043P0
N6044P0
N6045P0
N6058P0
N6109P0
N6110P0
N6111P0
N6112P0
N6113P0
N6120P0
N6200P00000001
N6201P00000001
N6202P00000000
N6210P500
N6211P1000
N6212P0
N6213P0
N6214P0
N6215P300
N6216P300
N6217P300
N6218P80
N6219P0
N6220P0
N6221P0
N6240A1P0A2P3A3P0A4P0A5P0A6P0
N6261P0
N6262P0
N6263P0
N6264P0
N6291P0
N6400P00000000
N6420A1P0A2P0A3P0A4P0A5P0A6P0
N6422A1P0A2P0A3P0A4P0A5P0A6P0
N6423A1P0A2P0A3P0A4P0A5P0A6P0
N6610P0
N6611P0
N6612P0
N6613P0
N6614P0
N6620P0
N6621P0
N6622P0
N6623P0
N6624P0
N6630P0
N6631P0
N6632P0
N6633P0
N6634P0
N7000P00000000
N7001P00000000
N7002P00000000
N7004P00000000
N7005P00000000
N7010P00000000
N7011P00000000
N7012P00000000
N7013P00000000
N7014P00000000
N7015P00000000
N7016P00000000
N7017P00000000
N7031P0
N7032P0
N7033P0
N7034P0
N7041P0
N7043P0
N7044P0
N7045P0
N7046P0
N7047P0
N7048P0
N7049P0
N7050P200
N7051P0
N7052P0
N7053P0
N7054P0
N7055P0
N7056P0
N7057P0
N7058P0
N7059P0
N7060P0
N7061P0
N7062P0
N7063P0
N7064P0
N7065P0
N7066P0
N7067P0
N7068P0
N7069P0
N7071P0
N7072P0
N7073P0
N7074P0
N7075P0
N7076P0
N7077P0
N7078P0
N7079P0
N7080P6
N7081P0
N7082P0
N7083P0
N7084P0
N7085P0
N7086P0
N7087P0
N7088P0
N7089P0
N7110A1P0A2P0A3P0A4P0A5P0A6P0
N7120P0
N7200P00000000
N7201P00000000
N7202P00000000
N7203P00000000
N7211P0
N7212P0
N7213P0
N7214P0
N7300P00000000
N7311P0
N7312P0
N7313P0
N7321P0
N7322P0
N7323P0
N7331P0
N7332P0
N7333P0
N7400P00001100
N7401P00000000
N7440P0
N7441P0
N7442P0
N7500P00000000
N7501P00000000
N7511P0
N7512P0
N7521P0
N7522P0
N7523P0
N7524P0
N7525P0
N7526P0
N7527P0
N7528P0
N7529P0
N7530P0
N7531P0
N7532P0
N7533P0
N7534P0
N7535P0
N7536P0
N7537P0
N7538P0
N7539P0
N7540P00000000
N7541P0
N7542P0
N7543A1P0A2P0A3P0A4P0A5P0A6P0
N7544P0
N7545P0
N7559P00000000
N7560P0
N7561P0
N7562P0
N7563P0
N7564P0
N7565P00000000
N7566P0
N7567P0
N7568P0
N7569P0
N7570P0
N7571P0
N7572P0
N7573P0
N7574P0
N7575P0
N7576P0
N7577P0
N7578P0
N7579P0
N7580P0
N7581P0
N7582P0
N7583P0
N7584P0
N7585P0
N7586P0
N7587P0
N7588P0
N7589P0
N7590P0
N7591P0
N7592P0
N7593P0
N7594P0
N7595P0
N7596P0
N7597P0
N7598P0
N7599P0
N7600P00000000
N7601P00000000
N7602P00000000
N7603P00000000
N7604P00000000
N7605P00000000
N7606P00000000
N7607P00000000
N7608P00000000
N7609P00000000
N7610P00000000
N7611P00000000
N7612P00000000
N7613P00000000
N7614P00000000
N7615P00000000
N7616P00000000
N7617P00000000
N7618P00000000
N7619P00000000
N7620P00000000
N7621P0
N7622P0
N7623P0
N7624P0
N7625P0
N7626P0
N7627P0
N7628P0
N7631P0
N7632P0
N7633P0
N7634P0
N7635P0
N7636P0
N7637P0
N7638P0
N7639P0
N7640P0
N7641P0
N7651P0
N7652P0
N7653P0
N7657P0
N7658P0
N7665P0
N7666P0
N7667P0
N7668P0
N7670P0
N7671P0
N7672P0
N7673P0
N7681P0
N7682P0
N7683P0
N7684P0
N7685P0
N7701A1P0A2P0A3P0A4P0A5P0A6P0
N7702A1P0A2P0A3P0A4P0A5P0A6P0
N7703A1P0A2P0A3P0A4P0A5P0A6P0
N7704A1P0A2P0A3P0A4P0A5P0A6P0
N7721A1P0A2P0A3P0A4P0A5P0A6P0
N7722A1P0A2P0A3P0A4P0A5P0A6P0
N7723A1P0A2P0A3P0A4P0A5P0A6P0
N7724A1P0A2P0A3P0A4P0A5P0A6P0
N7741A1P0A2P0A3P0A4P0A5P0A6P0
N7742A1P0A2P0A3P0A4P0A5P0A6P0
N7743A1P0A2P0A3P0A4P0A5P0A6P0
N7744A1P0A2P0A3P0A4P0A5P0A6P0
N7795P0
N7796A1P0A2P0A3P0A4P0A5P0A6P0
N7799P0
N8000P00000000
N8010P00000000
N8500P00000000
N8501P00000000
N8502P00000000
N8503P00000000
N8504P00000000
N8505P00000000
N8506P00000000
N8507P00000000
N8508P00000000
N8509P00000000
N8510P0
N8511P0
N8512P0
N8513P0
N8514P0
N8515P0
N8516P0
N8517P0
N8518P0
N8519P0
N8520P0
N8521P0
N8522P0
N8523P0
N8524P0
N8525P0
N8526P0
N8527P0
N8528P0
N8529P0
N8530P0
N8531P0
N8532P0
N8533P0
N8534P0
N8535P0
N8536P0
N8537P0
N8538P0
N8539P0
N8540P0
N8541P0
N8542P0
N8543P0
N8544P0
N8545P0
N8546P0
N8547P0
N8548P0
N8549P0
N8550P0
N8551P0
N8552P0
N8553P0
N8554P0
N9000P3
N9001P3
N9002P8
N9100P00001001
N9101P00000000
N9102P00100110
N9103P00000100
N9104P00000100
N9105P00000100
N9106P00000000
N9107P01100011
N9108P00101000
N9109P00001000
N9110P00000000
N9111P00011001
N9112P01000000
N9113P00000000
N9114P00000000
N9115P00000000
N9116P00010000
N9117P11000101
N9118P00010000
N9119P00000000
N9120P00000001
N9121P00000000
N9122P00000010
N9123P00000000
N9124P00000000
N9125P10000000
N9126P00001000
N9127P00000000
N9128P00000000
N9129P00000000
N9130P10000011
N9131P00000000
N9132P00000000
N9133P00000001
N9134P00000000
N9135P00000000
N9136P00000000
N9137P00001000
N9138P00000000
N9139P00000000
N9140P00000000
N9141P00000000
N9142P00000000
N9143P00000000
N9144P00001000
N9145P00000000
N9146P00000000
N9147P00000000
