- Fanuc 604 PC Alarm
Fanuc 604 PC Alarm
Hello good day, i obtain this alarm in a Fanuc 6M control (604 PC Alarm), checking the manual maintenance, suggest change the pcb (pg51):
Cause Checking Countermeasures
PCB A20B-0008-0440 is faulty. Make sure that PCB setscrews are fastened. Replace the PCB.
I can obtain this pcb of other 6M, however i no have clear the functions of this:
Replace this pcb of other control 6M there may be compatibility?
Program of change tool is in this pcb?
regards
Renato
- You may not post replies
- You may not edit your posts
Forum Rules
