How to go about getting om-c ladder edited for dnc function
Results 1 to 3 of 3
Thread: How to go about getting om-c ladder edited for dnc function
    Member Chopdr230's Avatar
    Sep 2019
    Default How to go about getting om-c ladder edited for dnc function
    Hi i have a miyano tsv-35 and it dose not have tape or dnc modes , no switches on the control . I am able to see the ladder and searched for g127.5 and its not there . Is it possible to have it added ? who or where would do this ? i currently only have 48k memory and can only run small programs . I have found some info on upgrading the memory but if possible id like to be able to drip feed my machine . any info would be greatly appreciated . Thanks
    May 2016
    Default Re: How to go about getting om-c ladder edited for dnc function
    I have a YCI Supermax with OMC. M50 and M51 turn DNC on and off. Not sure which is which. I think M51 on. If I find out different tomorrow at work I'll correct this. Can't promise this will work on your machine. You also need software to drip feed to your machine. dnc4u is what I use. Works great.
    Dec 2003
    There is a few older posts on the subject e.g. https://www.cnczone.com/forums/fanuc...m-ladders.html
    You need to find someone, hopefully local that has the Fanuc eeprom burner in order to program and store the modified ladder.
