Need Help! Fanuc OI-MF control will not change tool 9
Results 1 to 3 of 3
Thread: Fanuc OI-MF control will not change tool 9
    Activation process WAZP's Avatar
    Jun 2018
    Default Fanuc OI-MF control will not change tool 9
    First, Thanks for any help.
    This is a WOKE VMC with 24 tool changer and a Fanuc OI-MF control.
    All tool changer works fine except on tool 9.
    All other tools 0-8 & 10-24 load fine.
    In MDI or auto mode T9 gives an error: "EX1008 OVER COMMAND ERROR!"
    Any idea where the tool table is stored? I am guessing there is a bad number in tool 9.
    Thank, WAZP
    Dec 2009
    ROMANIA
    Default Re: Fanuc OI-MF control will not change tool 9
    The tool numbers are stored in the DATA TABLE from 500 or 1000,depends on MTB,but if yiu look on the pages you will see your tools.
    Member MrAverage's Avatar
    Oct 2019
    WAZP,
    I believe you can hit offset once or twice and plus over to tool management if it's been purchased and enabled for your machine.
    If it hasn't, EX1008 is a manufacturer's alarm, and you should be able to find the cause of it in the ladder.
