Problem with Fanuc - Illegal command G71-G76
Results 1 to 3 of 3
Thread: Problem with Fanuc - Illegal command G71-G76
    Oct 2003
    Pompano Beach FL
    Default Problem with Fanuc - Illegal command G71-G76
    I have a Hawk lathe with a 21i giving me the above error. I cannot figure out what the problem is.
    The first block is a straight drill cycle, no peck and it errors
    The second is a peck drill cycle (.083) and contains Q parameter, no error
    I tried adding Q0000 but that didn't work either.
    What should I try? Thanks!!
    Code blocks are below
    Error
    N84 G74 R.005
    N85 G74 Z-.025 F.0026
    N86 G80
    No Error
    N98 G74 R.005
    N99 G74 Z-2.1002 Q0835 F.0026
    N100 G80
    Marc
    Dec 2013
    Default Re: Problem with Fanuc - Illegal command G71-G76
    G74 requires the Q word. Try setting Q = Z Q0025
    or just do a G1 move.
    Jim Dawson
    Sandy, Oregon, USA
    Oct 2003
    Pompano Beach FL
    Quote Originally Posted by Jim Dawson View Post
    Thanks, I'll try that in the AM
    The code comes from my post processor in Bobcad. I'll take a look and see if I can fix that also.
    Marc
