that machine does not exist,was made with 0T system and now has 15TF,there are some VT20 machines with 15TF ,I have a back up from series MA-1968.
Hello to all
I have a Victor Vturn 20 lathe with a Fanuc 15 TF controller . Beause of the power source malfounction the memory of the controller dont run anymore. Does anybody have a backup of this Fanuc 15 TF .
This is what i see on the display when i start the machine (image attached).
Can anybody help me please?
Thank you in advance.
Razvan
- Need Help!- Fanuc oi-td total backup
- Need Help!- Fanuc backup
- Newbie- Fanuc OM PLC Backup
- Fanuc 11M Backup Parameters?
I need the parameter and PC parameter for Mori Seiki SL25M Fanuc 15TF.Please help me.
My email:hanseols@online.no
Hi after troubleshooting indexing C axis and changing of encoder the Base 0 card was removed and battery power plug to the card accidently pulled out so we have now Ram Parity Base0.
this machine has for many years had problems with communication on the two ports so no backup has been made.
All the different "Fanuc" people I hawe been in contact with says you have BIG problems and need special cards etc and all software from Mori Seiki and Fanuc !!!
The machine was working perfect exept communications with Pc on com port and indexing on C axis; didn't lock on some degrees.
Hajns
You lost all parameters (NC+PMC), programs, offsets etc. No boards are needed as far as I can see.
You will have to turn the control ON holding the 7 & 9 keys pressed until the memory address is counting down. Then you have to clear the FAPT area:
Power the control ON while pressing the backspace key.
Then press the “AUX” softkey. It will then ask for a request, type “CFINT”.
It will ask initialize yes or no, type yes. The screen will message you when it is complete.
Agree with Alex Fanuc, If you see regular screens (mutiple alarms after following my CLEAR procedure), you just have to reload data.
Now you have to get all the data back in...
Ok parameters and PMC ?? I still locking for a simular machine to ask for a backup ffrom,,!
Yes, NC and PMC parameters, any 9000 series programs you may need etc,
Hello
I lost my parameters in Battery fault
now i need the default parameter.
I have no backup. thats my fault
My controller is Fanuc 21it
My machine is 2 axis lathe (Pinacho Cobra180)
What can I do now?
Can u help me pls?
