Fanuc 6m + DNC how to ?
Results 1 to 2 of 2
Thread: Fanuc 6m + DNC how to ?
    Mar 2005
    Default Fanuc 6m + DNC how to ?
    Hi guys,
    need help, need to send the a programm to the fanuc 6m.
    it setup as parallel port. to the motherboard.
    the program is 01313.NC
    power light is ON
    Ready is ON
    it shows 01313.NC
    ready T1
    try Fanuc in mode programm and also Edit
    O-9999 read
    but the program does not transfer.
    what are we doing wrong parameter are set as default to parameter
    any idea ? or parameter to change.
    Mar 2005
    Default Re: Fanuc 6m + DNC how to ?
    Nevermind guys, fix the issue.
    issue was a limit switch on the Z axis that was loose. so it was doing it zeros but the connection was bad.
    was able to do the transfer all good.
    thanks.
