I would like to collect the data from a CNC machine which has equipped with FANUC 31i and FANUC 0i-d control unit. (for example; “running” , “stopped” , “standby” , “alarm” etc...) I have an IP address from the machine and I can ping to machine. But I could not find a way to get the data from the machine. May I ask you to help me about this problem?
Re: Read data from/On CNC Machine Fanuc Controller
Depending whether your plc advertise the OPC protocol, or if you have the license for it, you can use any OPC-UA Client to read/write data to and from pretty much any industrial controls and bots.
Kepware is one that comes to mind, there are several others clients also (free, open source, etc). I bet FANUC has one also? have you checked?
