Fanuc A06B-6079-HXXX over 21i-MA controller
Results 1 to 7 of 7
Thread: Fanuc A06B-6079-HXXX over 21i-MA controller
    Member Alamgeer's Avatar
    May 2018
    Default Fanuc A06B-6079-HXXX over 21i-MA controller
    Hi guys, Is there a way to link Fanuc A06B-6079-HXXX with Fanuc 21i-MA controller? As 21i has a HSSB link but 6079 doesn't. I heard there is a card in market that can communicate 6079 series amplifier over HSSB link. Is it true? If yes can I have a part number for that?
    Your help greatly appreciated.
    Apr 2011
    Default Re: Fanuc A06B-6079-HXXX over 21i-MA controller
    A20B-2100-0740 But this by no means is Fanuc LTD approved. (Sorry not for your drive)
    May 2018
    Quote Originally Posted by drdos View Post
    Thanks for response, but I'm looking something else. I want to use same 6079 control card with additional add-on to connect 6079 via HSSB.
    May 2018
    Hi drdos,
    I just found A13B-0154-B001 optical link would be the option to connect 6079 with 21i-MA. But do not know more about it. One of forum member used A13B-0154-B001 in Fanuc 16C but don't know the purpose of that. I also asked same question with him let see what I get response. Your help greatly appreciated. If we can't use A13B-0154-B001 with Fanuc-21i, Can I used it with Fanuc 16-MB to control 6096 series amplifier?
    Apr 2011
    The A13B-0154-B001 is used for the I/O LINK (Inputs and Outputs to the PMC). When the I/O link cable needs to be long then we use this so signal quality isn't lost. I never heard of anyone using it for what you want to use it for. Also, not sure that your servo software will support the older drives.
    May 2018
    Thank drdos
  7. #7
    May 2018
    I just found 6079 and 6096 have a same base module board, it just have different interface, have a look on attached pdf page. There should be something to communicate 6079 with Fanuc 21i control.
    Attached Files Attached Files
