Fanuc 6M Origin Resets with Reset button
Results 1 to 4 of 4
Thread: Fanuc 6M Origin Resets with Reset button
    Activation process legacymachining's Avatar
    Nov 2018
    Default Fanuc 6M Origin Resets with Reset button
    Hi Everyone, posted in kitamura section but since its generic to fanuc and i have no answers i was hoping to post to a more generalized category.
    anyway, i am used to a Tormach and picked up an 86 mycenter with fanuc 6m. I am having a hell of a time figuring out how to keep my G54 location set. Bascially i figured out that in order to set G5X i need to zero return the machine and tell it how far from zero return the x and y origin is. Great. Ill set it, jog it around a bit and go into some menus to setup a couple things, and out of habit or maybe necessity (maybe i overtravelled) i have to hit reset. When i do this, the absolute position changes to the G54 coordinates. this is incredibly irritating because i cant seem to get it properly setup to run a part. Can anyone help me out here, because maybe i am incorrectly using the control. Another thing i noticed, when i power up the machine it defaults to INC at the bottom, i toggle it to abs but it doesnt seem to affect this problem at all.
    PS man. abs. switch is on.
    To Recap my process:
    1. power up machine, hit abs button, zero return
    2. jog to x origin and write down coordinates
    3. jog to y origin and write down coordinates
    4.type in the coordinates for the G54 position location
    5. jog machine up and out of the way
    6. something requires a reset, may be an overtravel or clearing what i typed into the command
    7. absolute position changes to G54 coordinates that i typed in (essentially shifting the G54 whatever i moved in x,y,z)
    8. start all over while swearing
    HELP?!
    Dec 2009
    ROMANIA
    Default Re: Fanuc 6M Origin Resets with Reset button
    if you can not disable by hand that man/abs switch,it can be disabled by a data parameter from diagnose.
    do you have the ladder printed?
    May 2016
    United Kingdom
    I thought it was a system parameter for abs/inc start up and also for reverting back to original g53 position
    Nov 2018
    i dont have the ladder printed, i have the maintenance manual and i cannot find any parameters related to abs/man nor can i find any parameter related to reset function. im wondering if its a matter or reset clearing modals?? i really dont know
