Have you measured power at the that top plug? (Usually 220vac). If you have power there then it may be in the power supply. Try removing all the jumpers between it and the spindle drive to make sure that another unit is not dragging it down. My documentations shows at least 1 fuse on the circuit board in the power supply. (if you check for it make sure it has been powered off for more than 20 min).
