How can I look at the G80 cycles on a 31i model B?
Results 1 to 9 of 9
Thread: How can I look at the G80 cycles on a 31i model B?
    Member ezzywave's Avatar
    May 2011
    Default How can I look at the G80 cycles on a 31i model B?
    Jan 2005
    Default Re: How can I look at the G80 cycles on a 31i model B?
    Quote Originally Posted by ezzywave View Post
    I can't find them in the "MTB" folders. Anybody know how to do this?
    For what reason would you need to look at a G80, a G80 is used to cancel a canned cycle it has no other purpose
    Mactec54
    May 2011
    I meant one of the G80 canned cycles. G84, for instance. I want to see how Fanuc programs a G84 canned cycle.
    Member machinehop5's Avatar
    Aug 2009
    Dec 2012
    The Netherlands
    Hi ezzywave,
    Just like most Fanuc's, if you want Rigid Tapping:
    ( f.e. TAP M8X1.25 Metric )
    G95 ( MM/REV )
    M29 S500
    G84 Z-15. R5. F1.25
    G80
    G94 ( MM/MIN )
    or only G94 mode:
    G94 ( MM/MIN )
    M29 S500
    G84 Z-15. R5. F625 ( FEED = SPEED X PITCH = 500X1.25 )
    G80
    Check here for the Fanuc 30i-31i-32i Model B Operators Manual.
    Fanuc 30i 31i 32i Manuals User Guides - CNC Manual
    Regards,
    Heavy_Metal.
    Feb 2006
    india
    If you are asking about live-tool canned cycles on a lathe, here is a resource.
  7. #7
    Mar 2017
    Like how to "program" it or how Fanuc makes it work under the hood?
    look in the manual posted for the former
    The latter is in the software and cannot be seen, that I know of.
  8. #8
    May 2011
    Quote Originally Posted by generaldisarray View Post
    Yes! I want to see "how Fanuc makes it work under the hood"!
    With a G&L 8000 control you can enter a password which will allow you to view and edit all the G80 thru G89 cycles and the probing cycles. The G&L G84 cycle has 8(?) lines and many M codes.
    I want to know how the G84 cycle coordinates the spindle rotation with the tapping axis. Or single point threading on a cnc lathe.
  9. #9
    Mar 2017
    I am fairly certain that it is handled differently on the Fanuc from the G&L. If no one chimes in you can always call Fanuc.
    Your G&L sounds like they are using macro calls for those cycles,from a Fanuc viewpoint. And Fanuc allows macro calls from G code but I think the classic canned cycle numbers are verboten.
    I think Canned cycles are baked in at a much lower level than even the PMC or Ladder. You can alter several things about them with parameters but beyond that I couldnt tell you,
