must be open cnc ,u have a white rotary switch on the cnc ,back in the electric panel, put on F and u will have the NCBOOT32 menu and u can save the sram there.
Before this try to boot holding 6 and 7
also on touch screen you can hold press on the upper-left corner of the touch panel screen while power on.
one solution must work for you.
good luck
