The 0iT-C parameter manual I have shows WZR as being bit 7 in parameter #1201, not #1202.
Hi guys I just got 2 hwacheon lathes, hi techs. The small one has a 0i-TC controller and when you hit reset it changes the work set back to G54. We need to change it so that the current work set stays modul. I have found that #1201.7 = 0 should do that but it doesn't on both these machines. Also bit 7 isnt labeled WZR like it should be. Is this setting in a different parameter on this controller? All the rest of the Pumas we have in the shop are all set to = 0 and work fine.
Thanks for nay help
