Originally Posted by
pangoli
Hello everyone, I can not solve a problem with our Nakamura Tome TMC-30 lathe with Fanuc 0T - A control;
used daily without problems, one morning at startup has error 911, we perform the procedure for resetting the memory, presenting the status "not ready" you can not enter the parameters, we solve detaching the connector M20, now we can insert the parameters, the turret is switched off, the P key and the EOB key at start up can be resolved, the program is switched on, the spindle does not turn, no error message is issued, the fuses are OK, the PCB master card made to check by our technician cards does not seem to have problems, the spindle board is configured correctly, they are one thing, at the start of the machine will turn on the red alarm machine light, then turn off suffered, and the error 600 - 06 that disappears not as soon as the machine finishes the ignition procedure, can someone give me suggestions? I'm taking the first steps in the industry, I would like to solve on my own if possible
thank you all
