who is the manufacturer of the machine?
give some name of the builder and maybe we can help you.
Hello everyone,
We needed to reload all parameters on a lathe with a O-T control. Once we have entered all parameters the machine was put back to live. all axis and spindle are moving. EXCEPT for the TURRET not moving at all when we send the Tool change from MDI mode.
Does anyone has a procedure for resetting the Turret. Machine was working fine before the parameters were dumped.
Thank you a bunch in advance.
FLEX
there may be more parameters needed. Did you get all the pmc parametres set up too. can you view the ladder on that control? what version ot OT is it b, c, d etc.
only needed to put diagnostics along original parameters and check x21.5 bit is permanently high or not ????
quick-cnc
I think an "X" address is an input to the PLC. You would need a printout of the ladder to know what the value would need to be to get the outcome you want.
