FANUC 12M start up Problems
Results 1 to 7 of 7
Thread: FANUC 12M start up Problems
    Member daee's Avatar
    Feb 2019
    Default FANUC 12M start up Problems
    I have a milling machine equipped with FANUC 12M control.the problem is that the machine starts booting on power up but stucks in between and stops comletion of booting process giving the following messgae displays on CRT/MDI. i upload picture for reference
    F12M14 3051E
    ROM TEST END
    RAM TEST :END
    SERVO ROM TEST:END
    BUBBLE INITIALIZE :END
    [ALL TESTS:END]
    Means all tests end up succesfully but the machine do not boot further.
    if any one can help plz.
    Dec 2009
    ROMANIA
    Default Re: FANUC 12M start up Problems
    open the cabinet and look for red leds on the mainboard or some error display and come back here.
    btw you did not upload any picture as you said.
    Feb 2019
    Quote Originally Posted by zavateandu View Post
    i checked the LED lights on all the electronic cards (BMU, MAin CPU, Axis Card, Position indicator) but none of them matches to those indicated in maintenance manual.Firs it gave "Bubble initialize error" , so i followed the procedure to go to IPL mode and initialize the bubble memory, ten the error cleared but the machine was still not able to boot further.now, when i want to go to IPL mode while pressing and holding down the "." and "_" keys as mentioned in the manual, the machine does not go to the IPL mode. Here is the picture.
    Feb 2019
    I have uploaded the picture twice but i dont know whats wrong with the picture upload.it does not show here.
    https://drive.google.com/open?id=17b...U64fqg5C2MMlny
    Feb 2019
    Please help.
    Apr 2009
    Where are you located? Please provide a phone #.
  7. #7
    Feb 2019
    Please check inbox for details.
