Hi, I have a A06B-0829-B200 , a A06B-0143-B077 and a A06B-0128-B177 servo ac motors and l need the drivers, Does anyone know what driver number do I need? To run these servos.
The B200 is a spindle motor. (aP22) Potential drive is A06B-6088-H226#H500
0143 is an A12/3000 servo
0128 is an A6/3000 servo - The two of them together can potentially be driven by a A06B-6079-H208 or A06B-6096-H208
Separately they can potentially be driven by a A06B-6079-H105 or A06B-6096-H105
These are suggestions and I suggest you check things out on your own. There is A TON more you should look into before just slapping a drive and motor together. For starters you also need to select a power supply module. (PSM)
Get yourself a GE Fanuc manual GFZ-65162E/03 or Fanuc B651692/03 Alpha Series Descriptions Manual as place to start. Again... only a place to start.
