Need Help! Fanuc 0i-MA 4th axis Install - Daewoo Doosan 3016d
Results 1 to 15 of 15
Thread: Fanuc 0i-MA 4th axis Install - Daewoo Doosan 3016d
    Member avongil's Avatar
    Sep 2008
    Default Fanuc 0i-MA 4th axis Install - Daewoo Doosan 3016d
    Hi, I have purchased a used rotary table and would like to install it on this mill. I am having a hard time getting anyone to come out and do it. Would like to set it up as much as possible to learn how it's done anyway.
    Does anyone have a procedure for setting one up? I would love to document this and leave it up for people to look through.
    What I have done so far:
    Purchased Rotary Table with fanuc motor and compatible servo drive (emailed Fanuc)
    https://photos.app.goo.gl/Aq6EwEfMqkHL16CW7
    Made sure the machine had the 4th axis options. Fanuc was actually really helpful.
    https://photos.app.goo.gl/TyQaJPEyGnoKbbAA6
    I read through motordude's thread. Would like to know if anyone has a procedure like this for 0i-MA?
    https://www.cnczone.com/forums/showt....%20Difficult?
    Jan 2014
    Do you have ladder written for the 4th axis?
    Search your ladder for G130.3
    Not super familiar with that specific control.
    Sep 2008
    Default Re: Fanuc 0i-MA 4th axis Install - Daewoo Doosan 3016d
    Yes, when I searched for it I found a bunch of 4th axis logic. home, jog, interlocks ...
    Jan 2014
    I do not see a photo of the motor tag..
    Not the encoder tag.
    You need to make sure the new motor and drive combination will match parameter sets. If the MTB pre set the parameters it would most likely be some combination of what THEY would add on. Likely not what you had bought, but maybe.
    Sep 2008
    I called Fanuc and got the recommended combo then purchased the drive. The 4th came off the same machine but an 08 model vs 2003.
    I forgot about the motor info. The tag also fell off... 4th axis motor: A06B-0223-B000
    2003 Daewoo DMV 3016d with a Fanuc 0iM-A
    Serial number: AV4E0138
    Fanuc 0i-MA 0a2b-0280-B502 2002-08
    X&Y servo: a06b-6079-h208
    Z servo: a06b-6079-h105
    Spindle amp: a06b-6102-h215#h520
    Power Supply Module - A06b-6087-H126
    4th axis Servo Amp: A06B-6079-H104
    Encoder: aiA1000: A860-2000-T301
    Jan 2014
    Quote Originally Posted by avongil View Post
    Check parameter 2020.
    See if 273 is in it for the 4th axis.
  7. #7
    Sep 2008
    Ok, I set parameter 9943.3 to 1 and restarted the machine. The A axis is now present and shows Motor ID 61.
  8. #8
    Sep 2008
    Should't the motor ID be set to 233?
    Middle number here?
    I just found: Alpha Series AC Servo Motor Parameter Manual, GFZ-65150E/03
  9. #9
    Jan 2014
    What is parameter 9943? I have never used this.
    Could be because it is an MA control, I may not be able to help much more without the parameter cross references from MA to MC or MD. Do you have any MA manuals?
    Anyways, from what I can tell that motor you have, the motor ID should be 273 for HRV2 or 173 for HRV1 control. The middle number is the specification ID.
    I do not see any motors with an ID of 61.
    The motor you have is an alpha i series, aiF4/4000.
  10. #10
    Sep 2008
    I have these plus the ones that came with the machine.
    Fanuc 0i-MA Manuals User Guides - CNC Manual
  11. #11
    Sep 2008
    I see what you are saying. Its on page 12 of this manual: http://cti-sumy.com.ua/files/library...r%20Manual.pdf
    should I set that parameter and start connecting things up?
  12. #12
    Jan 2014
    Yes after you set 8130 to 4. I would set the motor ID and hook the amp and motor up. Normally I would do an auto set of the parameters, Then tune from there..But you may mess other axis up if you do not do it exactly right. So if I were you in your situation. Go through the 1800 and 2000 parameters. Look at the end of the parameter manual for the basic motor settings. See what alarms come up and work through them. Then when you can effectively move the axis with no alarms, you will need to set the gear ratios and other positioning parameters, to move to an accurate position. This is assuming the ladder works out.
    It's a good thing those amps don't have FSSB comm to set up. That's more of a pain in the A$$.
  13. #13
    Jan 2014
    Ah, also see if there is a clamp on that rotary table. You will need to supply a valve for unclamp, before you try to move the axis or you will be chasing your tail after movement/excess detect alarms. Good luck.
  14. #14
    Sep 2008
    Yes it has one! I will see if I can put a relay and valve in.
  15. #15
    Member baonam2019's Avatar
    Jul 2019
    I also have an Oi-MD milling machine that is in need of a 4th axis extension, can you help me set the parameters for connecting the 4th axis? The ladder also has options for the 4th axis written. Are you connected successfully? You have experienced please help me.
    Thank!
