hey there i have a takisawa mac v-3 mill.fanuc o-m control and an atc 10-e tool changer on a 24 tool magazine that comes out through the back of the machine.
all parameters where lost and i believe that i have replaced all of them including the 9001 macro..
here's my issue....
running the tool change program to load tools,the machine stops completely when m80 comes up...and it will just sit there forever.it will not time out or go into alarm..the door opens but the tool magazine will not wont come out.
same thing in handle..i can press the solenoid for it to come out and it does. it will rotate and do what it should.and then reverse back in and close the door.
it gets signal to reverse the mag but does not get signal to the solenoid to go forward..
relays are good and solenoid is also good.
z zero and z secondary are also good.
diagnostic shows everything is satisfied for the magazine to come forward.
i'm stumped and have had two companies out here checking it out to no avail.
maybe missing a specific parameter?
I WOULD REALLY APPRECIATE SOME HELP
THANKS
