How did you input the parameter ? I have the same problem.
Please floks, shine a light this way.
We needed to replace the motherboard on this 0-MB control. it belongs to a DAEWOO mill.
New board came in, but we are not able to set the machine up on the correct status for receiving parameters from PC.
As soon as I turn machine ON, the JOG status shows up and ignores MODE selector switch. Stays in JOG mode and it does not allow any data transferring.
Software version is a 415-12 I am sure there is a trick to it because all hardware had been checked ok.
Thank you in advance.
flex
PD: we tried unplugging M1 connector that goes from operator pendant all the way to the I/O card, and this is the only way that we are changing MODE to MDI mode. Still It won´t let us change the parameters. We are able to type in the numbers, but then we hit INPUT and it´s ignored. nothing changes.
PWE is set to 1
E-Stop is pushed in.
The only data we have been able to modify is OFFSETS.
Need more information.
