FAQ: Is it FANUC Zero-M or Letter-O-M ?
Results 1 to 3 of 3
Thread: FAQ: Is it FANUC Zero-M or Letter-O-M ?
    Mar 2011
    Question FAQ: Is it FANUC Zero-M or Letter-O-M ?
    This has been an annoying question for a while.
    Is the basic / minimalist FANUC CNC G-Code mode properly written as 0-M or O-M ?
    Is this the same thing as RS-274 ?
    Does 0-M / O-M exist as an actual FANUC model or is it a sort of backrevision name for a product which originally had no model number?
    Sort of like how the "Apple 1" wasn't called that, but was just simply "the Apple computer" because there was no "Apple II" yet?
    Reference: https://en.wikipedia.org/wiki/File:A...t_Oct_1976.jpg
    Apr 2011
    Default Re: FAQ: Is it FANUC Zero-M or Letter-O-M ?
    It is Fanuc 0 (Zero). Started out as 0MA for Mills and 0TA for lathes. Then through the years Fanuc released the 0MB/0TB but was shortly lived as the 0MC/0TC came out and was around for many years. Then the 0MD/0TD came out for a short time replaced by the 0iMA/0iTA, then 0iMB/0iTB, then 0iMC/0iTC then that was replaced by the 0iMD/0iTD which was around for many years as well. Fanuc replaced that with the 0iMF/0iTF. Each controller has different features. The biggest being that Fanuc changed the parameters structure to be closer to that of the 16/18 family with the start of the "i" series. Hope this helps.
    Dec 2003
    The Fanuc systems were all numeric, and because some numbers are unlucky in Japanese etc, there is no system 4 for example.
