Originally Posted by
freakycnc
Be very careful here! there may be 300VDC which will blow the probes off your scope if you slip!!! S5 will not let current flow through the power section. I would measure from B1 - U0 through B2R - N2 with a voltmeter first. This will tell you if you have an open base drive XSTR. If you have 300VDC then check the fuses on the top board. Then check the same terminal on CN5 or CN4 - CN6 depending on the size of the drive looking for the small voltage described in the drive MNT manual. If it's 0.0 - .8 V the drivers for that XSTR is no good. 1.0 - 1.5 should be OK.
freakycnc
