Need Help! murata wiedemann C-2000 problem
Results 1 to 3 of 3
Thread: murata wiedemann C-2000 problem
    *Registered User* ruben483's Avatar
    Nov 2018
    Post murata wiedemann C-2000 problem
    hi friend, need help please
    one day the machine show this error:
    604 PMC alarm : rom parity
    605 PMC alarm : ladder over
    607 PMC alarm : 5 axes
    TDC controller 1021
    401 servo (vrdy off)
    I turned off the machine and then turned it on again and now it does that, the machie is moving the axes X and Y at the same time is punching.
    this machine is an murata wiedemann C-2000Q s/n: 2499
    control fanuc OP-C series.
    thanks.
    Activation process noziz's Avatar
    Aug 2018
    Default Re: murata wiedemann C-2000 problem
    I think you can unplug then plug card PMC into master PCB.
    With alarm 401 mean: X, Y axis velocity control READY signal (VRDY) turns off
    Check DGN as picture attach. Then search the solution for this error.
    Attached Thumbnails Attached Thumbnails murata wiedemann C-2000 problem-123-png
    Nov 2018
    replace the pmc and still the problem, but thanks anyway.
