Parameter 0019#7 (1xxxxxxx) x means don't matter
DBCD On the diagnostic screen, the data of a timer counter is displayed in binary/decimal.
Hi I have a fanuc omf, I recently had a repair done that wiped my parameters, I have written in the parameters by hand however the parameters for the keep relays etc don't seem to have a page to be entered into, I've been told to look for d310 however none of the pages have letters and the only free parameters left are the binary 0000001 type, which does not match the values I need to insert, can anyone shed any light on this?
- how to shut off Fapt on a 1999 daewoo with FANUC Puma 200 with FANUC 18T control
- Need Help!- Fanuc Robocut Alpha 0B with Fanuc Series 16-W control 910 SRAM Parity System Error
- Weird Rs232 issue/Mystery with Fanuc 6M on Mori Seiki . Calling all Fanuc Masters !
- Need Help!- Fanuc drill tap center equipped with Fanuc OM-C i/o card details
If you change parameter 19 bit 7 it changes how the D300's look. You have whole numbers for values but you only have binary being displayed. Once you change parameter 19 bit 7 you will see the binary changes to decimals so you can enter your data.
Does that help.
