check your power supply module , spindle amp and axis amps they have not got power o them
Hello,
I need help to rectify the following errors:
750: Serial Spindle link error
1536: fssb number of amps is small alarm
I am newbie to this, if you can give me solution with complete description to solve, also if link of the video will help.
Please let me know as soon as possible.
5136 Number of amps is small. Number of amps does not match the FSSB configuration.
This is usually the fiber optic cable is broken between drives.
tejzcena.. Dear you were able to solve the failure .. I have the same problem
