Murata/Muratec uses switches inside the electrical cabinet to enable parameter setting and other stuff.
Verzonden vanaf mijn iPhone met Tapatalk
Dear all,
I have a punch machine with Fanuc 0-P controller.
After replace battery without power on, i have to clear memory to start machine.
But it is strange, i only receive 2 error: 417 and 427 for X,Y digital parameter without error 100: Parameter write enable.
So that, i turned on E-stop(ESP) switch, the screen still show "NOT READY" instead of "EMERGENCY" so i can't input Parameter enable =1 on Setting Handy page.
And its strange, i turn on or turn off E-stop switch, bit 701.5 DGN still =1.
And on the master PCB, SO led red and SI led green light.
Anyone know this problem and can you help me?
Thank for your reading and best regard.
Is it your mean?
I turned on this switch.
Today, after replaced 2 socket chip: OE1,OE2; the screen showed alarm "100: parameter enable" and on setting handy page: parameter enable =1.
But i still can't input parameter. So sad.
Yes, thats the switch I mean. You probably lost all your parameters, so start with inputting the option parameters. They should work.
But i can't input parameter. Eg: in line N000: i type "P 11110101" then press "INPUT" button, but the screen still show "P 11110101" and N000 still 00000000
it gives me this error
1019 IN PUNCH CYCLE
1037
I/T COUPLING ALARM
