The X-axis wear compensation in my Fanuc 0-TC control is in radial increments. A wear adjustment of 0.001", for example, makes a diametral change of 0.002". Is there a setting that will change to the comp to diameter values?Similar Threads: cutter wear comp on mitsubishi meldas 60/60sNeed Help!- tool wear/cutter compNeed Help!- Cutter comp and tool wearNewbie- Wear offset when diameter is set to zero?Need Help!- Using tool diameter for cutter comp
Hi, Check parameter 0001 #4 -- ORC; 1: Offset value becomes a diameter designation. 0: Offset value becomes a radius designation. Check also 0001 #3 -- TOC: 1: Offset is cancelled by RESET button. 0: Offset is not cancelled by RESET button. Regards, Heavy_Metal.
View Tag Cloud
Forum Rules
