ps error 128 trying to DNC
Results 1 to 6 of 6
Thread: ps error 128 trying to DNC
    romanr9999's Avatar
    Jul 2018
    Default ps error 128 trying to DNC
    I have a milling center with a Fanuc O-MD control and I'm having problems to DNC run a program from the computer.
    I select MEM-DNC and press the Cycle Start key and I get LSK flashing in the lower right corner of the screen.
    When I start transmitting from the computer, the first two lines go through and then I get a ps 128 alarm. First line is of code is the % character.
    From the OFFSETS screen pressing the OUTPUT-START key I get all the data sent correctly to the computer, so I assume cable and RS2332 parameters are correct.
    Is this assumption correct?
    Any ideas?
    Please
    May 2016
    United Kingdom
    Default Re: ps error 128 trying to DNC
    What happens when you load a program to the memory without dnc
    Mar 2007
    RI
    Quote Originally Posted by romanr9999 View Post
    Any ideas?
    Please
    Hi, did you find the problem? I got the same problem now. Please advice the solution..
    Thanks before..
    Member machinehop5's Avatar
    Aug 2009
    ...DNC drip feeding Fanuc 128 Alarm "ILLEGAL MACRO SEQUENCE NUMBER" ...sounds like your program has Sub Programs in it or Macro Calls which I don't think is allowed using an external PC for running a program. one more thing to check use XON/XOFF
    DJ
    Mar 2007
    RI
    Quote Originally Posted by machinehop5 View Post
    DJ
    Hi DJ..
    I'm not using sub program while drip feeding or macro calls..
    Okay, i will check pc setings..
    Thanks a lot
    Mar 2007
    RI
    Finally DNC transfer is back to normal after replacing PC serial card..
