The max voltage is set in the inverter. You would run them with a 200 volt class inverter. The real question is: How do you plan on commutating them? Are you using the Fanuc inverters? I went through this a few months ago and gave up trying to untangle the commutation issues and just repowered the machine with DMM servos.
