Originally Posted by
Absent_Minded
Hi Robowi, thank you for your reply. As I have written twice in previous posts, I tried [0] + [DELETE] and "Power-On", which always hangs the control in the "BUBBLE READ" screen. Tried with two different motherboards and two different memory boards, both of which work in other machines. The only difference is the software and I am temped to upgrade this machine's software to a newer series & version. I would like to try to get the procedure that is specific to this SRAM PCB and which I know exits, before I resort to upgrading the software or initialing this SRAM board in a machine that has later software. Currently those machines are running hot jobs and are not available to me. The machine in question is running at the moment -- I individually cleared program memory & parameter memory, then reloaded each respectively and subsequently cleared the offsets by O-9999 [INPUT]. This seems to have worked, but I would still like to get the procedure. I have a gut feeling that the problem is going to reoccur... call it 32 years of experience as a service engineer, I guess. I want to be ready just in case and I know the procedure exists. I'd also like to post it here for future reference if someone else has a similar problem and does a search here for an answer. I hate leaving a thread unanswered as I have seen so many times in the past. I guess I'm too tenacious for my own good sometimes, but that's probably one of the things that makes me a good service engineer.
-Ed
