fanuc spindle amplifier low rpm problems
Results 1 to 7 of 7
Thread: fanuc spindle amplifier low rpm problems
    *Registered User* Tonymc's Avatar
    Jul 2018
    Default fanuc spindle amplifier low rpm problems
    hello i have fanuc leadwell mcv-550s and i can't get the spindle to run over 200 rpms does anyone know of what would do that my
    ac spindle servo unit is a fanuc ltd A06B-6044-H008 ?
    Member guhl's Avatar
    Aug 2007
    Russian Federation
    Default Re: fanuc spindle amplifier low rpm problems
    what is the load (amperage)?
    Jul 2018
    .3 amps the 130hz to 170hz the hz are fluctuating is that normal ?
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Tonymc View Post
    What would you use it for below 200 RPM
    Mactec54
    Jul 2018
    I don't want to run it below 200 rpms the machine want go over 200 rpms
    Jul 2018
    a20b-9000-0010 I moved this sensor and it sped up a little bit maybe 300 rpms does anyone now the gap setting
  7. #7
    May 2014
    thailand
    check spindle amp parameter.
