Originally Posted by
Bdrangdo
Your handwheel should typically have 4 connections, 5v, 0v, A, and B. with power on measure the voltage between A and 0v and turn the wheel slowly, the voltage should fluctuate between 0.5v and 4v it is hard to see unless you turn the handle slowly. Then test between B and 0v it should be the same.
The noise could be coming from a number of sources, you will need to remove the servos and try to turn the screws by hand a see how smoothly they turn. Be careful with the "Z" axis it may have a brake on it. Check to see if it is counterbalanced and anticipate what will happen when the motor is removed. I don't know what this machine is or how big it is, some machines have a hole in the pillar to allow a shaft to go through the counterbalance to stop the "Z" axis moving.
far.
Are the encoders absolute ?. If so there could be batteries in them which store the homing data.
