Need Help! Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
Results 1 to 8 of 8
Thread: Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
    *Registered User* KyleC1's Avatar
    Jun 2018
    Post Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
    Hi can anyone help me on my 10" Megabore Fanuc 18i-TB.
    Baruffaldi turret with DMS-08BF drive it wasnt indexing and turned out the motor is faulty so they replaced the motor and could only index one tool at a time anything more would through up a alarm turret zero search time out, we installed the new drive and now doesnt index at all and give a 4.1 alarm on drive and same alarm turret zero search time out please help
    Dec 2012
    The Netherlands
    Jun 2018
    Hi Thank you will it have the zero position procedure on the DMS-08BF?
    Jun 2018
    They dont have the zero set procedure do you know where i Can download it?
    Dec 2009
    ROMANIA
    Default Re: Baruffaldi Turret On 10" Megabore Fanuc 18i-TB
    Quote Originally Posted by KyleC1 View Post
    it is a beta drive for the turret?
    if yes,u should have a screen special for this drive.
    May 2016
    United Kingdom
    You will possibly have to go through the PMM parameters
  7. #7
    Member Florsita3's Avatar
    Feb 2019
    Who are you, where is installed your Machine? I can send you all technical info for easy to solve, and reserved procedure for to check, for diagnostic, and for alignment RESOLVER/MOTOR.
    Get me also before Label on servomotor, and Label on servodrive DMS...
  8. #8
    Feb 2019
    Quote Originally Posted by zavateandu View Post
    Not exist BETA DRIVE on this machine Megabore, there is a CUSTOM PROCEDURE for to install and for to SET after CHANGING SERVOMOTOR B5602p or Proper DRIVE DMS. Only need Serial N. of Turret and i can specify exactly procedure.
  9. #9
    Hi MEN
    All these links are unavailable. Do you have the list of alarms, please give me
    I use this drive model according to the attached images
    I recently had a problem and the error 9.2 is displayed on the drive
    Please advise how to fix this error
  10. #10
  11. #11
    I use this drive model Baruffaldi turret Type : DMS-08BF
    Please advise how to fix this error Do you have the list of alarms, please give me.
