Originally Posted by
drdos
Fanuc out of the Box does NOT preform Rigid Tap. The machine tool Builder must implement it. Also, Rigid Tap is a "Paid" option from Fanuc. Again, the MTB would have bought that option from Fanuc when building the machine. Fanuc also says you have to have a "Fanuc" digital spindle amp to have it. M29 was typical but not carved in stone as Fanuc says you can change the M code with parameter 256. Also there are a handful of parameters that say how RT works (including G84).
