let us know number of card which is with alarm
A20B-....-....
Hi!
I have some problem about the lathe machine Hankook with fanuc 18T.
I can't power up. I check the system electric. the power supply is ok but the main board show led alarm A2. What is fault?
- Need Help!- Fanuc 10tf, Axis Torque Alarm, mem Z axis Alarm, already changed Z drive and motor?
- alarm 408 servo alarm "serial not RDY", αP18 fanuc mtor code
- Problem- Fanuc 6T-B alarm 402:servo Alarm
- Fanuc alarm 401 + 414 + servo amplifier alarm 08
- Need Help!- Fanuc Powermate D Alarm 414 (LV5V Control Power Low Alarm)
A20B-....-....
board graphic A20B-8001-0821
board main A16B-3200-021
I read the maintenance book. It instruction the led alarm means " The system is stopped before the CPU is active".
Mainboard Status : 0 0 0 0 ( green)
.................Alarm : x 0 x ( red )
Graphic Status : x x
.........................x x
.........Alarm : A1 x x A3
.....................A2 0 x A4
0: On - x: Off
did you test power supply?
if you have another one swap it
but you should have backup of parameters etc., because there is the battery in power supply
when I got this alarm on CPU card I cleaned all connectors on small PCBs with rubber eraser
but you should have got parameters backup before taking out any PCB
DID you found the solution?
I have the same problem !!! Please help me
I just had the same issue on a Mori with an MSC-518 control (Fanuc 18tc). Machine operator was changing an insert when the screen went blank and control shut off. Only alarms were as shown above.
Using the manual to trouble shoot lead me nowhere. I ended up swapping out PMC boards, daughter boards, and clearing parameters, nope.
Turns out, the driver board for the monitor died. Apparently it can cause the control to hang on bootup. I never would have thought the monitor could cause this issue. I've had monitors fail, but the machine don't stop. Our Mori uses a A02B-0222-C110 LCD monitor assembly which includes a A16B-2200-0033/01A board. The board failed. It blew a 5amp fuse on it near the 24v input. Blew the replacement fuse also. It was NOT the LCD screen or the bulb that cause the problem. It was the board attached directly to it.
I found it cheaper to buy the whole assembly rather than just the A16B-2200-0033 board (eBay). Fanuc wanted $2400 for repair (7-2023). When the used replacement (eBay) monitor assembly showed up, I got nervous because it had a A16B-2200-0053 rather than the 0033 board. Looked very similar and it was attached to the assembly sharing the same number as the original. I swapped in the entire assembly and it worked fine.
So, if anyone runs into this issue, maybe, just maybe it's your monitor's driver board.
I searched the internet and no one ever gave a solution to this problem on multiple websites, so I'm doing my part and adding to this post. Hopefully this helps someone.
-Matt
