I am having a problem setting the X offset on my machine (a Cincinnati Hawk) . I don't use this machine very often so it is very possible I have forgotten something. The Z seems to work fine.
At first I thought the problem was limited to 1 position - T1010, now I think it is intermittent. I cannot see a patter.
Turn a part manually, measure dimension (.656) , enter X.656 in proper row/column , press measure and - the machine calculates the wrong dimension. If I do it again it increments the dimension.
So I tried it on an empty position (T1212) and it worked as expected. And then tried again and it doesn't. Sometimes it works then not.
