I created a tool probing macro and it worked great. I just wanted to input some messages for the users to know what to do but I've spent the last 4 hours googling and testing without any luck now.
With the following code I get a 115 P/S ALARM indicating a wrong variable.
O0001
#3006=1 (TEST)
M99
If I replace #3006 with #3000 I can get a alarm output but that's not what I'm after. On the alarm/opr button I have a operator message soft key that should be able to display this. I also enabled a 900 parameter that was related to operator message and external operator message but none of those made any impact. Is there a different variabel used for operator message on OM-C? Can anyone see what I do wrong?
That explains a lot Is there other good ways of giving a message to the operator on what to do? Now I've used M0 and created a comment below in the program but then I have to access the program screen to see the message.
