Originally Posted by
HVACturnedCNC
For anybody who might be reading this looking for answers. I was told by Mitsubishi the Scale could not be repaired. They stated " the way the part is assembled, if you try to disassemble it you will ruin it" . So like any good service tech I ignored what they said HA ( I mean the part is bad, whats the worst I could do right?!) This particular part is pressed together with it's own internal bearing. I carefully separated the pieces of this part and cleaned everything ( except the bearing) with de natured alcohol. Very carefully pressed everything back together and re-installed into my machine. Just out of curiosity because let's face it $6,919 is a good bit to spend on a part. After re-installing said part and re-assembling my machine I proceeded to put it to the test. From 1rpm-1,000rpm and back, forward and reverse, small jumps in speed, large jumps in speed. I am happy to say that this part works like a charm now. A few hours of labor and about $2 worth of de-natured alcohol later I managed to save $7k. Hope this helps anyone who might be looking for answers on this particular subject.
